File being truncated
eschind
Minnesota
I followed the https://winscp.net/eng/docs/library#vbnet example for transferring a file using SFTP. For some reason the file is being truncated to 80KB when it is programmatically uploaded to the site. I contacted the vendor whose server we are uploading it to and they said there are not file size limitations in place.
Wondering if anyone has some ideas/suggestions I can test out to try and get the entire file uploaded.
Thanks.
Re: File being truncated
Re: Log File
There's nothing wrong from WinSCP perspective.
The common problem is that there's not enough space in the file system and the server silently ignores any write attempts.
