Support UNC path for local directory
Szeraax
Utah, USA
When running from command line and specifying -rawsettings Localdirectory=\\10.x.x.x\share\folder, I get the error:
Error - WinSCP
UNC paths are not supported.
OK Help
I would LOVE to be able to put in the actual path instead of having to do a local folder.
Re: Support UNC path for local directory
Support for having a UNC path in a local panel of the GUI is planned:
https://winscp.net/tracker/133
But you cannot have the UNC path as the current working directory in Windows. Try using cd \\10.x.x.x\share\folder\ in console (cmd.exe). It does not work.
So in scripting this will never work.
Szeraax
Utah, USA
Oh of course! Well, at least get works fine with UNC. Thanks!
