Task Scheduler not working- Error: No such file - Script: Failed
tmorris431
We moved this process to a new PC with a local login and then my IT support left. Now Task Scheduler is not uploading the files automatically. Made sure WinSCP was thru firewall. If I open WinSCP and upload all files manually it works. If I run it through Task Scheduler it fails.
Use Task Scheduler to run Command line ftpsched.bat:
"c:\program files\winscp\winscp.exe"
/script=C:\Users\RE_Queue\Documents\ReeherFTP\ftpcommands.txt
/log=C:\Users\RE_Queue\Documents\ReeherFTP\reeherlog.txt
Script ftpcommands.txt includes:
option batch abort
# Connect
open sftp://hartford:password@sftp.reeher.com/
# Force binary mode transfer
option transfer binary
# Change local directory
lcd "C:\Users\RE_queue\Downloads\Queue output"
# Upload the file to current working directory
put *.CSV
# Disconnect
close
# Exit WinSCP
Exit
WinSCP version 5.7.6 (Build 5874)
Microsoft Windows 7 Professional 32-bit
Transfer protocol: SFTP
reeherlog.txt
. 2015-12-04 04:00:00.664 --------------------------------------------------------------------------
. 2015-12-04 04:00:00.664 WinSCP Version 5.7.6 (Build 5874) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2015-12-04 04:00:00.664 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2015-12-04 04:00:00.664 Log level: Normal
. 2015-12-04 04:00:00.664 Local account: alumni-115\RE_Queue
. 2015-12-04 04:00:00.664 Working directory: C:\Users\RE_queue\Documents\ReeherFTP
. 2015-12-04 04:00:00.664 Process ID: 3560
. 2015-12-04 04:00:00.664 Command-line: "c:\program files\winscp\winscp.exe" /script=C:\Users\RE_Queue\Documents\ReeherFTP\ftpcommands.txt /log=C:\Users\RE_Queue\Documents\ReeherFTP\reeherlog.txt
. 2015-12-04 04:00:00.664 Time zone: Current: GMT-5, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/8/2015, DST End: 11/1/2015
. 2015-12-04 04:00:00.664 Login time: Friday, December 04, 2015 4:00:00 AM
. 2015-12-04 04:00:00.664 Script: Retrospectively logging previous script records:
> 2015-12-04 04:00:00.664 Script: option batch abort
< 2015-12-04 04:00:00.664 Script: batch abort
< 2015-12-04 04:00:00.664 Script: reconnecttime 120
> 2015-12-04 04:00:00.664 Script: option confirm off
< 2015-12-04 04:00:00.664 Script: confirm off
> 2015-12-04 04:00:00.664 Script: open sftp://hartford:***@sftp.reeher.com/
. 2015-12-04 04:00:00.664 Session name: hartford@sftp.reeher.com (Ad-Hoc site)
. 2015-12-04 04:00:00.664 Host name: sftp.reeher.com (Port: 22)
. 2015-12-04 04:00:00.664 User name: hartford (Password: Yes, Key file: No)
. 2015-12-04 04:00:00.664 Tunnel: No
. 2015-12-04 04:00:00.664 Transfer Protocol: SFTP
. 2015-12-04 04:00:00.664 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2015-12-04 04:00:00.664 Disable Nagle: No
. 2015-12-04 04:00:00.664 Proxy: none
. 2015-12-04 04:00:00.664 Send buffer: 262144
. 2015-12-04 04:00:00.664 SSH protocol version: 2; Compression: No
. 2015-12-04 04:00:00.664 Bypass authentication: No
. 2015-12-04 04:00:00.664 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2015-12-04 04:00:00.664 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2015-12-04 04:00:00.664 KEX: dh-gex-sha1,dh-group14-sha1,dh-group1-sha1,rsa,WARN
. 2015-12-04 04:00:00.664 SSH Bugs: A,A,A,A,A,A,A,A,A,A,A,A
. 2015-12-04 04:00:00.664 Simple channel: Yes
. 2015-12-04 04:00:00.664 Return code variable: Autodetect; Lookup user groups: A
. 2015-12-04 04:00:00.664 Shell: default
. 2015-12-04 04:00:00.664 EOL: 0, UTF: 2
. 2015-12-04 04:00:00.664 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2015-12-04 04:00:00.664 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2015-12-04 04:00:00.664 SFTP Bugs: A,A
. 2015-12-04 04:00:00.664 SFTP Server: default
. 2015-12-04 04:00:00.664 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2015-12-04 04:00:00.664 Cache directory changes: Yes, Permanent: Yes
. 2015-12-04 04:00:00.664 DST mode: 1
. 2015-12-04 04:00:00.664 Looking up host "sftp.reeher.com"
. 2015-12-04 04:00:01.740 Connecting to 216.17.74.137 port 22
. 2015-12-04 04:00:04.829 Server version: SSH-2.0-OpenSSH_5.3
. 2015-12-04 04:00:04.829 Using SSH protocol version 2
. 2015-12-04 04:00:04.829 We claim version: SSH-2.0-WinSCP_release_5.7.6
. 2015-12-04 04:00:04.876 Doing Diffie-Hellman group exchange
. 2015-12-04 04:00:05.000 Doing Diffie-Hellman key exchange with hash SHA-256
. 2015-12-04 04:00:05.718 Verifying host key rsa2 0x10001,0xcb83aef9ee6159fc a92fe9f7ee26032d 61d9fda0c20a9a26 2f53448564725275 9362be273d05424b 02a0281bfdb43285 ffe1fdc8ac2689ac ce9f3dbf70bff856 5f87cc2b55fd093d eff8bfb8cb03778c 47df366b7c5f8717 e9f9a78615cf3bfb 1015c85320969297 c440973464f4317a 973c3532ffe4f2d3 d15c64ad54764903 9778196aa420b0d6 3748894e78c8891a 333ac635d720e759 c28bf20c0989b840 b31bb9f9c5c8e053 400e06c333d276d9 155a5d421b4121db 05ca25e184689e91 fe27c1e0f71ec405 f3077ac2ab186d96 acf29a399fdc1d62 d5b5980444841914 b2e79818215a0c2f 17d8a5e49b04ae3b a93291f7e9669555 a4df5e092ecf4101 with fingerprint ssh-rsa 2048 65:04:44:8a:e6:8e:67:22:f1:30:bc:e6:fa:67:27:3b
. 2015-12-04 04:00:05.718 Host key matches cached key
. 2015-12-04 04:00:05.718 Host key fingerprint is:
. 2015-12-04 04:00:05.718 ssh-rsa 2048 65:04:44:8a:e6:8e:67:22:f1:30:bc:e6:fa:67:27:3b
. 2015-12-04 04:00:05.718 Initialised AES-256 SDCTR client->server encryption
. 2015-12-04 04:00:05.718 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2015-12-04 04:00:05.718 Initialised AES-256 SDCTR server->client encryption
. 2015-12-04 04:00:05.718 Initialised HMAC-SHA-256 server->client MAC algorithm
! 2015-12-04 04:00:05.843 Using username "hartford".
. 2015-12-04 04:00:05.890 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2015-12-04 04:00:05.890 Using stored password.
. 2015-12-04 04:00:05.890 Sent password
. 2015-12-04 04:00:05.952 Access granted
. 2015-12-04 04:00:05.952 Opening session as main channel
. 2015-12-04 04:00:05.999 Opened main channel
. 2015-12-04 04:00:06.108 Started a shell/command
. 2015-12-04 04:00:06.108 --------------------------------------------------------------------------
. 2015-12-04 04:00:06.108 Using SFTP protocol.
. 2015-12-04 04:00:06.108 Doing startup conversation with host.
> 2015-12-04 04:00:06.108 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2015-12-04 04:00:06.155 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2015-12-04 04:00:06.155 SFTP version 3 negotiated.
. 2015-12-04 04:00:06.155 Unknown server extension posix-rename@openssh.com="1"
. 2015-12-04 04:00:06.155 Supports statvfs@openssh.com extension version "2"
. 2015-12-04 04:00:06.155 Unknown server extension fstatvfs@openssh.com="2"
. 2015-12-04 04:00:06.155 We believe the server has signed timestamps bug
. 2015-12-04 04:00:06.155 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 string are not mandatory
. 2015-12-04 04:00:06.155 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2015-12-04 04:00:06.155 Getting current directory name.
. 2015-12-04 04:00:06.155 Getting real path for '.'
> 2015-12-04 04:00:06.155 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2015-12-04 04:00:06.202 Type: SSH_FXP_NAME, Size: 35, Number: 16
. 2015-12-04 04:00:06.202 Real path is '/upload'
. 2015-12-04 04:00:06.202 Startup conversation with host finished.
< 2015-12-04 04:00:06.202 Script: Active session: [1] hartford@sftp.reeher.com
> 2015-12-04 04:00:06.202 Script: option transfer binary
< 2015-12-04 04:00:06.202 Script: transfer binary
> 2015-12-04 04:00:06.202 Script: lcd "C:\Users\RE_queue\Downloads\Queue output"
< 2015-12-04 04:00:06.202 Script: C:\Users\RE_queue\Downloads\Queue output
> 2015-12-04 04:00:06.202 Script: put *.CSV
. 2015-12-04 04:00:06.202 Copying 23 files/directories to remote directory "/upload"
. 2015-12-04 04:00:06.202 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2015-12-04 04:00:06.202 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2015-12-04 04:00:06.202 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2015-12-04 04:00:06.202 File: '4.1 Code Translation_Funds.CSV' [2015-12-03T11:00:36.716Z] [294110]
. 2015-12-04 04:00:06.280 Copying "4.1 Code Translation_Funds.CSV" to remote directory started.
. 2015-12-04 04:00:06.280 Binary transfer mode selected.
. 2015-12-04 04:00:06.280 Checking existence of file.
> 2015-12-04 04:00:06.280 Type: SSH_FXP_LSTAT, Size: 47, Number: 263
< 2015-12-04 04:00:06.326 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2015-12-04 04:00:06.326 Checking existence of partially transfered file.
> 2015-12-04 04:00:06.326 Type: SSH_FXP_LSTAT, Size: 56, Number: 519
< 2015-12-04 04:00:06.373 Type: SSH_FXP_ATTRS, Size: 37, Number: 519
. 2015-12-04 04:00:06.373 Resuming file transfer.
. 2015-12-04 04:00:06.373 Opening remote file.
> 2015-12-04 04:00:06.373 Type: SSH_FXP_OPEN, Size: 64, Number: 771
< 2015-12-04 04:00:06.404 Type: SSH_FXP_HANDLE, Size: 13, Number: 771
> 2015-12-04 04:00:06.420 Type: SSH_FXP_WRITE, Size: 4121, Number: 1286
. 2015-12-04 04:00:06.420 24 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-04 04:00:06.420 Type: SSH_FXP_CLOSE, Size: 13, Number: 7684
< 2015-12-04 04:00:06.451 Type: SSH_FXP_STATUS, Size: 24, Number: 1286
< 2015-12-04 04:00:06.498 Type: SSH_FXP_STATUS, Size: 24, Number: 1542
< 2015-12-04 04:00:06.498 Type: SSH_FXP_STATUS, Size: 24, Number: 1798
< 2015-12-04 04:00:06.529 Type: SSH_FXP_STATUS, Size: 24, Number: 2054
< 2015-12-04 04:00:06.529 Type: SSH_FXP_STATUS, Size: 24, Number: 2310
< 2015-12-04 04:00:06.529 Type: SSH_FXP_STATUS, Size: 24, Number: 2566
< 2015-12-04 04:00:06.545 Type: SSH_FXP_STATUS, Size: 24, Number: 2822
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 3078
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 3334
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 3590
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 3846
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 4102
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 4358
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 4614
< 2015-12-04 04:00:06.576 Type: SSH_FXP_STATUS, Size: 24, Number: 4870
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 5126
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 5382
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 5638
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 5894
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 6150
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 6406
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 6662
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 6918
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 7174
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 7430
< 2015-12-04 04:00:06.623 Type: SSH_FXP_STATUS, Size: 24, Number: 7684
< 2015-12-04 04:00:06.623 Status code: 0
> 2015-12-04 04:00:06.623 Type: SSH_FXP_REMOVE, Size: 47, Number: 7949
< 2015-12-04 04:00:06.670 Type: SSH_FXP_STATUS, Size: 24, Number: 7949
< 2015-12-04 04:00:06.670 Status code: 0
> 2015-12-04 04:00:06.670 Type: SSH_FXP_RENAME, Size: 98, Number: 8210
< 2015-12-04 04:00:06.701 Type: SSH_FXP_STATUS, Size: 29, Number: 8210
< 2015-12-04 04:00:06.701 Status code: 2, Message: 8210, Server: No such file, Language:
* 2015-12-04 04:00:06.701 (ETerminal) No such file or directory.
* 2015-12-04 04:00:06.701 Error code: 2
* 2015-12-04 04:00:06.701 Error message from server: No such file
. 2015-12-04 04:00:06.701 Asking user:
. 2015-12-04 04:00:06.701 Transfer was successfully finished, but temporary transfer file '4.1 Code Translation_Funds.CSV.filepart' could not be renamed to target file name '4.1 Code Translation_Funds.CSV'. If the problem persists, you may try to turn off transfer resume support. ("No such file or directory.
. 2015-12-04 04:00:06.701 Error code: 2
. 2015-12-04 04:00:06.701 Error message from server: No such file")
< 2015-12-04 04:00:06.701 Script: Transfer was successfully finished, but temporary transfer file '4.1 Code Translation_Funds.CSV.filepart' could not be renamed to target file name '4.1 Code Translation_Funds.CSV'. If the problem persists, you may try to turn off transfer resume support.
< 2015-12-04 04:00:06.701 Script: No such file or directory.
< 2015-12-04 04:00:06.701 Error code: 2
< 2015-12-04 04:00:06.701 Error message from server: No such file
* 2015-12-04 04:00:06.701 (EScpSkipFile) Transfer was successfully finished, but temporary transfer file '4.1 Code Translation_Funds.CSV.filepart' could not be renamed to target file name '4.1 Code Translation_Funds.CSV'. If the problem persists, you may try to turn off transfer resume support.
* 2015-12-04 04:00:06.701 No such file or directory.
. 2015-12-04 04:00:06.701 Script: Failed
. 2015-12-04 04:00:06.701 Script: Exit code: 1
. 2015-12-04 04:00:06.701 Closing connection.
. 2015-12-04 04:00:06.701 Sending special code: 12
. 2015-12-04 04:00:06.701 Sent EOF message
Re: Task Scheduler not working- Error: No such file - Script: Failed
Show us a log for the successful "manual" upload.
This has nothing to do with a firewall. The connection is ok.
tmorris431
Here is the WinSCP log from uploading the files manually instead of through the task scheduler.
. 2015-12-07 08:17:16.272 Copying 23 files/directories to remote directory "/upload/"
. 2015-12-07 08:17:16.272 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2015-12-07 08:17:16.272 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2015-12-07 08:17:16.272 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2015-12-07 08:17:16.273 File: 'C:\Users\RE_Queue\Downloads\Queue output\4.1 Code Translation_Funds.CSV' [2015-12-04T11:01:00.391Z] [294110]
. 2015-12-07 08:17:16.275 Copying "C:\Users\RE_Queue\Downloads\Queue output\4.1 Code Translation_Funds.CSV" to remote directory started.
. 2015-12-07 08:17:16.276 Binary transfer mode selected.
. 2015-12-07 08:17:16.276 Checking existence of file.
> 2015-12-07 08:17:16.276 Type: SSH_FXP_LSTAT, Size: 47, Number: 1543
< 2015-12-07 08:17:16.276 Type: SSH_FXP_STATUS, Size: 24, Number: 1284
. 2015-12-07 08:17:16.276 Discarding reserved response
< 2015-12-07 08:17:16.318 Type: SSH_FXP_ATTRS, Size: 37, Number: 1543
. 2015-12-07 08:17:16.318 Checking existence of partially transfered file.
> 2015-12-07 08:17:16.318 Type: SSH_FXP_LSTAT, Size: 56, Number: 1799
< 2015-12-07 08:17:16.359 Type: SSH_FXP_STATUS, Size: 29, Number: 1799
< 2015-12-07 08:17:16.359 Status code: 2
. 2015-12-07 08:17:16.359 Opening remote file.
> 2015-12-07 08:17:16.359 Type: SSH_FXP_OPEN, Size: 72, Number: 2051
< 2015-12-07 08:17:16.401 Type: SSH_FXP_HANDLE, Size: 13, Number: 2051
> 2015-12-07 08:17:16.401 Type: SSH_FXP_WRITE, Size: 4121, Number: 2566
. 2015-12-07 08:17:16.420 40 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:17:16.420 Type: SSH_FXP_CLOSE, Size: 13, Number: 13060
< 2015-12-07 08:17:16.443 Type: SSH_FXP_STATUS, Size: 24, Number: 2566
< 2015-12-07 08:17:16.485 Type: SSH_FXP_STATUS, Size: 24, Number: 2822
< 2015-12-07 08:17:16.519 Type: SSH_FXP_STATUS, Size: 24, Number: 3078
< 2015-12-07 08:17:16.525 Type: SSH_FXP_STATUS, Size: 24, Number: 3334
< 2015-12-07 08:17:16.526 Type: SSH_FXP_STATUS, Size: 24, Number: 3590
< 2015-12-07 08:17:16.526 Type: SSH_FXP_STATUS, Size: 24, Number: 3846
< 2015-12-07 08:17:16.526 Type: SSH_FXP_STATUS, Size: 24, Number: 4102
< 2015-12-07 08:17:16.567 Type: SSH_FXP_STATUS, Size: 24, Number: 4358
< 2015-12-07 08:17:16.567 Type: SSH_FXP_STATUS, Size: 24, Number: 4614
< 2015-12-07 08:17:16.567 Type: SSH_FXP_STATUS, Size: 24, Number: 4870
< 2015-12-07 08:17:16.568 Type: SSH_FXP_STATUS, Size: 24, Number: 5126
< 2015-12-07 08:17:16.568 Type: SSH_FXP_STATUS, Size: 24, Number: 5382
< 2015-12-07 08:17:16.568 Type: SSH_FXP_STATUS, Size: 24, Number: 5638
< 2015-12-07 08:17:16.569 Type: SSH_FXP_STATUS, Size: 24, Number: 5894
< 2015-12-07 08:17:16.569 Type: SSH_FXP_STATUS, Size: 24, Number: 6150
< 2015-12-07 08:17:16.608 Type: SSH_FXP_STATUS, Size: 24, Number: 6406
< 2015-12-07 08:17:16.609 Type: SSH_FXP_STATUS, Size: 24, Number: 6662
< 2015-12-07 08:17:16.609 Type: SSH_FXP_STATUS, Size: 24, Number: 6918
< 2015-12-07 08:17:16.609 Type: SSH_FXP_STATUS, Size: 24, Number: 7174
< 2015-12-07 08:17:16.610 Type: SSH_FXP_STATUS, Size: 24, Number: 7430
< 2015-12-07 08:17:16.610 Type: SSH_FXP_STATUS, Size: 24, Number: 7686
< 2015-12-07 08:17:16.611 Type: SSH_FXP_STATUS, Size: 24, Number: 7942
< 2015-12-07 08:17:16.611 Type: SSH_FXP_STATUS, Size: 24, Number: 8198
< 2015-12-07 08:17:16.611 Type: SSH_FXP_STATUS, Size: 24, Number: 8454
< 2015-12-07 08:17:16.612 Type: SSH_FXP_STATUS, Size: 24, Number: 8710
< 2015-12-07 08:17:16.612 Type: SSH_FXP_STATUS, Size: 24, Number: 8966
< 2015-12-07 08:17:16.612 Type: SSH_FXP_STATUS, Size: 24, Number: 9222
< 2015-12-07 08:17:16.650 Type: SSH_FXP_STATUS, Size: 24, Number: 9478
< 2015-12-07 08:17:16.650 Type: SSH_FXP_STATUS, Size: 24, Number: 9734
< 2015-12-07 08:17:16.650 Type: SSH_FXP_STATUS, Size: 24, Number: 9990
< 2015-12-07 08:17:16.651 Type: SSH_FXP_STATUS, Size: 24, Number: 10246
< 2015-12-07 08:17:16.651 Type: SSH_FXP_STATUS, Size: 24, Number: 10502
< 2015-12-07 08:17:16.651 Type: SSH_FXP_STATUS, Size: 24, Number: 10758
< 2015-12-07 08:17:16.652 Type: SSH_FXP_STATUS, Size: 24, Number: 11014
< 2015-12-07 08:17:16.652 Type: SSH_FXP_STATUS, Size: 24, Number: 11270
< 2015-12-07 08:17:16.652 Type: SSH_FXP_STATUS, Size: 24, Number: 11526
< 2015-12-07 08:17:16.656 Type: SSH_FXP_STATUS, Size: 24, Number: 11782
< 2015-12-07 08:17:16.692 Type: SSH_FXP_STATUS, Size: 24, Number: 12038
< 2015-12-07 08:17:16.695 Type: SSH_FXP_STATUS, Size: 24, Number: 12294
< 2015-12-07 08:17:16.698 Type: SSH_FXP_STATUS, Size: 24, Number: 12550
< 2015-12-07 08:17:16.699 Type: SSH_FXP_STATUS, Size: 24, Number: 12806
< 2015-12-07 08:17:16.707 Type: SSH_FXP_STATUS, Size: 24, Number: 13060
< 2015-12-07 08:17:16.707 Status code: 0
> 2015-12-07 08:17:16.707 Type: SSH_FXP_REMOVE, Size: 47, Number: 13325
< 2015-12-07 08:17:16.748 Type: SSH_FXP_STATUS, Size: 24, Number: 13325
< 2015-12-07 08:17:16.748 Status code: 0
> 2015-12-07 08:17:16.748 Type: SSH_FXP_RENAME, Size: 98, Number: 13586
< 2015-12-07 08:17:16.789 Type: SSH_FXP_STATUS, Size: 24, Number: 13586
< 2015-12-07 08:17:16.790 Status code: 0
. 2015-12-07 08:17:16.790 Preserving timestamp [2015-12-04T11:01:00.000Z]
> 2015-12-07 08:17:16.790 Type: SSH_FXP_SETSTAT, Size: 63, Number: 2313
< 2015-12-07 08:17:16.831 Type: SSH_FXP_STATUS, Size: 24, Number: 2313
< 2015-12-07 08:17:16.831 Status code: 0
. 2015-12-07 08:17:16.831 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\4.1 Code Translation_Funds.CSV' [294110]
. 2015-12-07 08:17:16.834 File: 'C:\Users\RE_Queue\Downloads\Queue output\Activity Details_3.1b.CSV' [2015-12-04T11:51:13.196Z] [47451707]
. 2015-12-07 08:17:16.901 Copying "C:\Users\RE_Queue\Downloads\Queue output\Activity Details_3.1b.CSV" to remote directory started.
. 2015-12-07 08:17:16.902 Binary transfer mode selected.
. 2015-12-07 08:17:16.902 Checking existence of file.
> 2015-12-07 08:17:16.902 Type: SSH_FXP_LSTAT, Size: 42, Number: 13831
< 2015-12-07 08:17:16.943 Type: SSH_FXP_ATTRS, Size: 37, Number: 13831
. 2015-12-07 08:17:16.943 Checking existence of partially transfered file.
> 2015-12-07 08:17:16.943 Type: SSH_FXP_LSTAT, Size: 51, Number: 14087
< 2015-12-07 08:17:16.985 Type: SSH_FXP_STATUS, Size: 29, Number: 14087
< 2015-12-07 08:17:16.985 Status code: 2
. 2015-12-07 08:17:16.985 Opening remote file.
> 2015-12-07 08:17:16.985 Type: SSH_FXP_OPEN, Size: 67, Number: 14339
< 2015-12-07 08:17:17.026 Type: SSH_FXP_HANDLE, Size: 13, Number: 14339
> 2015-12-07 08:17:17.026 Type: SSH_FXP_WRITE, Size: 32764, Number: 14854
. 2015-12-07 08:17:25.634 2890 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:17:25.634 Type: SSH_FXP_CLOSE, Size: 13, Number: 386052
< 2015-12-07 08:17:25.636 Type: SSH_FXP_STATUS, Size: 24, Number: 383750
< 2015-12-07 08:17:25.639 Type: SSH_FXP_STATUS, Size: 24, Number: 384006
< 2015-12-07 08:17:25.660 Type: SSH_FXP_STATUS, Size: 24, Number: 384262
< 2015-12-07 08:17:25.664 Type: SSH_FXP_STATUS, Size: 24, Number: 384518
< 2015-12-07 08:17:25.667 Type: SSH_FXP_STATUS, Size: 24, Number: 384774
< 2015-12-07 08:17:25.670 Type: SSH_FXP_STATUS, Size: 24, Number: 385030
< 2015-12-07 08:17:25.673 Type: SSH_FXP_STATUS, Size: 24, Number: 385286
< 2015-12-07 08:17:25.677 Type: SSH_FXP_STATUS, Size: 24, Number: 385542
< 2015-12-07 08:17:25.684 Type: SSH_FXP_STATUS, Size: 24, Number: 385798
< 2015-12-07 08:17:26.406 Type: SSH_FXP_STATUS, Size: 24, Number: 386052
< 2015-12-07 08:17:26.406 Status code: 0
> 2015-12-07 08:17:26.406 Type: SSH_FXP_REMOVE, Size: 42, Number: 386317
< 2015-12-07 08:17:26.449 Type: SSH_FXP_STATUS, Size: 24, Number: 386317
< 2015-12-07 08:17:26.449 Status code: 0
> 2015-12-07 08:17:26.449 Type: SSH_FXP_RENAME, Size: 88, Number: 386578
< 2015-12-07 08:17:26.491 Type: SSH_FXP_STATUS, Size: 24, Number: 386578
< 2015-12-07 08:17:26.491 Status code: 0
. 2015-12-07 08:17:26.491 Preserving timestamp [2015-12-04T11:51:13.000Z]
> 2015-12-07 08:17:26.491 Type: SSH_FXP_SETSTAT, Size: 58, Number: 14601
< 2015-12-07 08:17:26.533 Type: SSH_FXP_STATUS, Size: 24, Number: 14601
< 2015-12-07 08:17:26.533 Status code: 0
. 2015-12-07 08:17:26.533 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Activity Details_3.1b.CSV' [47451707]
. 2015-12-07 08:17:26.533 File: 'C:\Users\RE_Queue\Downloads\Queue output\Activity History_3.1a.CSV' [2015-12-04T12:12:27.191Z] [5442965]
. 2015-12-07 08:17:26.587 Copying "C:\Users\RE_Queue\Downloads\Queue output\Activity History_3.1a.CSV" to remote directory started.
. 2015-12-07 08:17:26.592 Binary transfer mode selected.
. 2015-12-07 08:17:26.592 Checking existence of file.
> 2015-12-07 08:17:26.592 Type: SSH_FXP_LSTAT, Size: 42, Number: 386823
< 2015-12-07 08:17:26.633 Type: SSH_FXP_ATTRS, Size: 37, Number: 386823
. 2015-12-07 08:17:26.634 Checking existence of partially transfered file.
> 2015-12-07 08:17:26.634 Type: SSH_FXP_LSTAT, Size: 51, Number: 387079
< 2015-12-07 08:17:26.675 Type: SSH_FXP_STATUS, Size: 29, Number: 387079
< 2015-12-07 08:17:26.675 Status code: 2
. 2015-12-07 08:17:26.675 Opening remote file.
> 2015-12-07 08:17:26.675 Type: SSH_FXP_OPEN, Size: 67, Number: 387331
< 2015-12-07 08:17:26.716 Type: SSH_FXP_HANDLE, Size: 13, Number: 387331
> 2015-12-07 08:17:26.718 Type: SSH_FXP_WRITE, Size: 32764, Number: 387846
. 2015-12-07 08:17:27.613 323 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:17:27.613 Type: SSH_FXP_CLOSE, Size: 13, Number: 430596
< 2015-12-07 08:17:27.613 Type: SSH_FXP_STATUS, Size: 24, Number: 428038
< 2015-12-07 08:17:27.616 Type: SSH_FXP_STATUS, Size: 24, Number: 428294
< 2015-12-07 08:17:27.619 Type: SSH_FXP_STATUS, Size: 24, Number: 428550
< 2015-12-07 08:17:27.642 Type: SSH_FXP_STATUS, Size: 24, Number: 428806
< 2015-12-07 08:17:27.645 Type: SSH_FXP_STATUS, Size: 24, Number: 429062
< 2015-12-07 08:17:27.648 Type: SSH_FXP_STATUS, Size: 24, Number: 429318
< 2015-12-07 08:17:27.651 Type: SSH_FXP_STATUS, Size: 24, Number: 429574
< 2015-12-07 08:17:27.654 Type: SSH_FXP_STATUS, Size: 24, Number: 429830
< 2015-12-07 08:17:27.657 Type: SSH_FXP_STATUS, Size: 24, Number: 430086
< 2015-12-07 08:17:27.658 Type: SSH_FXP_STATUS, Size: 24, Number: 430342
< 2015-12-07 08:17:27.749 Type: SSH_FXP_STATUS, Size: 24, Number: 430596
< 2015-12-07 08:17:27.749 Status code: 0
> 2015-12-07 08:17:27.749 Type: SSH_FXP_REMOVE, Size: 42, Number: 430861
< 2015-12-07 08:17:27.791 Type: SSH_FXP_STATUS, Size: 24, Number: 430861
< 2015-12-07 08:17:27.791 Status code: 0
> 2015-12-07 08:17:27.791 Type: SSH_FXP_RENAME, Size: 88, Number: 431122
< 2015-12-07 08:17:27.856 Type: SSH_FXP_STATUS, Size: 24, Number: 431122
< 2015-12-07 08:17:27.856 Status code: 0
. 2015-12-07 08:17:27.856 Preserving timestamp [2015-12-04T12:12:27.000Z]
> 2015-12-07 08:17:27.856 Type: SSH_FXP_SETSTAT, Size: 58, Number: 387593
< 2015-12-07 08:17:27.903 Type: SSH_FXP_STATUS, Size: 24, Number: 387593
< 2015-12-07 08:17:27.903 Status code: 0
. 2015-12-07 08:17:27.903 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Activity History_3.1a.CSV' [5442965]
. 2015-12-07 08:17:27.903 File: 'C:\Users\RE_Queue\Downloads\Queue output\Addresses_1.2.CSV' [2015-12-04T13:42:58.702Z] [60913489]
. 2015-12-07 08:17:27.981 Copying "C:\Users\RE_Queue\Downloads\Queue output\Addresses_1.2.CSV" to remote directory started.
. 2015-12-07 08:17:27.981 Binary transfer mode selected.
. 2015-12-07 08:17:27.981 Checking existence of file.
> 2015-12-07 08:17:27.981 Type: SSH_FXP_LSTAT, Size: 34, Number: 431367
< 2015-12-07 08:17:28.012 Type: SSH_FXP_ATTRS, Size: 37, Number: 431367
. 2015-12-07 08:17:28.012 Checking existence of partially transfered file.
> 2015-12-07 08:17:28.012 Type: SSH_FXP_LSTAT, Size: 43, Number: 431623
< 2015-12-07 08:17:28.059 Type: SSH_FXP_STATUS, Size: 29, Number: 431623
< 2015-12-07 08:17:28.059 Status code: 2
. 2015-12-07 08:17:28.059 Opening remote file.
> 2015-12-07 08:17:28.059 Type: SSH_FXP_OPEN, Size: 59, Number: 431875
< 2015-12-07 08:17:28.106 Type: SSH_FXP_HANDLE, Size: 13, Number: 431875
> 2015-12-07 08:17:28.106 Type: SSH_FXP_WRITE, Size: 32764, Number: 432390
. 2015-12-07 08:17:38.746 3712 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:17:38.746 Type: SSH_FXP_CLOSE, Size: 13, Number: 908804
< 2015-12-07 08:17:38.746 Type: SSH_FXP_STATUS, Size: 24, Number: 906502
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 906758
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 907014
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 907270
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 907526
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 907782
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 908038
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 908294
< 2015-12-07 08:17:38.809 Type: SSH_FXP_STATUS, Size: 24, Number: 908550
< 2015-12-07 08:17:38.856 Type: SSH_FXP_STATUS, Size: 24, Number: 908804
< 2015-12-07 08:17:38.856 Status code: 0
> 2015-12-07 08:17:38.856 Type: SSH_FXP_REMOVE, Size: 34, Number: 909069
< 2015-12-07 08:17:38.902 Type: SSH_FXP_STATUS, Size: 24, Number: 909069
< 2015-12-07 08:17:38.902 Status code: 0
> 2015-12-07 08:17:38.902 Type: SSH_FXP_RENAME, Size: 72, Number: 909330
< 2015-12-07 08:17:38.934 Type: SSH_FXP_STATUS, Size: 24, Number: 909330
< 2015-12-07 08:17:38.934 Status code: 0
. 2015-12-07 08:17:38.934 Preserving timestamp [2015-12-04T13:42:58.000Z]
> 2015-12-07 08:17:38.934 Type: SSH_FXP_SETSTAT, Size: 50, Number: 432137
< 2015-12-07 08:17:38.980 Type: SSH_FXP_STATUS, Size: 24, Number: 432137
< 2015-12-07 08:17:38.980 Status code: 0
. 2015-12-07 08:17:38.980 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Addresses_1.2.CSV' [60913489]
. 2015-12-07 08:17:38.980 File: 'C:\Users\RE_Queue\Downloads\Queue output\Appeal Entity_2.3.CSV' [2015-12-04T17:29:29.432Z] [256872141]
. 2015-12-07 08:17:38.996 Copying "C:\Users\RE_Queue\Downloads\Queue output\Appeal Entity_2.3.CSV" to remote directory started.
. 2015-12-07 08:17:38.996 Binary transfer mode selected.
. 2015-12-07 08:17:38.996 Checking existence of file.
> 2015-12-07 08:17:38.996 Type: SSH_FXP_LSTAT, Size: 38, Number: 909575
< 2015-12-07 08:17:39.043 Type: SSH_FXP_ATTRS, Size: 37, Number: 909575
. 2015-12-07 08:17:39.043 Checking existence of partially transfered file.
> 2015-12-07 08:17:39.043 Type: SSH_FXP_LSTAT, Size: 47, Number: 909831
< 2015-12-07 08:17:39.090 Type: SSH_FXP_STATUS, Size: 29, Number: 909831
< 2015-12-07 08:17:39.090 Status code: 2
. 2015-12-07 08:17:39.090 Opening remote file.
> 2015-12-07 08:17:39.090 Type: SSH_FXP_OPEN, Size: 63, Number: 910083
< 2015-12-07 08:17:39.121 Type: SSH_FXP_HANDLE, Size: 13, Number: 910083
> 2015-12-07 08:17:39.136 Type: SSH_FXP_WRITE, Size: 32764, Number: 910598
. 2015-12-07 08:18:38.033 15683 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:18:38.033 Type: SSH_FXP_CLOSE, Size: 13, Number: 2919428
< 2015-12-07 08:18:38.064 Type: SSH_FXP_STATUS, Size: 24, Number: 2916870
< 2015-12-07 08:18:38.064 Type: SSH_FXP_STATUS, Size: 24, Number: 2917126
< 2015-12-07 08:18:38.064 Type: SSH_FXP_STATUS, Size: 24, Number: 2917382
< 2015-12-07 08:18:38.064 Type: SSH_FXP_STATUS, Size: 24, Number: 2917638
< 2015-12-07 08:18:38.064 Type: SSH_FXP_STATUS, Size: 24, Number: 2917894
< 2015-12-07 08:18:38.064 Type: SSH_FXP_STATUS, Size: 24, Number: 2918150
< 2015-12-07 08:18:38.080 Type: SSH_FXP_STATUS, Size: 24, Number: 2918406
< 2015-12-07 08:18:38.080 Type: SSH_FXP_STATUS, Size: 24, Number: 2918662
< 2015-12-07 08:18:38.080 Type: SSH_FXP_STATUS, Size: 24, Number: 2918918
< 2015-12-07 08:18:38.080 Type: SSH_FXP_STATUS, Size: 24, Number: 2919174
< 2015-12-07 08:18:38.095 Type: SSH_FXP_STATUS, Size: 24, Number: 2919428
< 2015-12-07 08:18:38.095 Status code: 0
> 2015-12-07 08:18:38.095 Type: SSH_FXP_REMOVE, Size: 38, Number: 2919693
< 2015-12-07 08:18:38.142 Type: SSH_FXP_STATUS, Size: 24, Number: 2919693
< 2015-12-07 08:18:38.142 Status code: 0
> 2015-12-07 08:18:38.142 Type: SSH_FXP_RENAME, Size: 80, Number: 2919954
< 2015-12-07 08:18:38.189 Type: SSH_FXP_STATUS, Size: 24, Number: 2919954
< 2015-12-07 08:18:38.189 Status code: 0
. 2015-12-07 08:18:38.189 Preserving timestamp [2015-12-04T17:29:29.000Z]
> 2015-12-07 08:18:38.189 Type: SSH_FXP_SETSTAT, Size: 54, Number: 910345
< 2015-12-07 08:18:38.236 Type: SSH_FXP_STATUS, Size: 24, Number: 910345
< 2015-12-07 08:18:38.236 Status code: 0
. 2015-12-07 08:18:38.236 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Appeal Entity_2.3.CSV' [256872141]
. 2015-12-07 08:18:38.236 File: 'C:\Users\RE_Queue\Downloads\Queue output\Appeals_2.2.CSV' [2015-12-04T11:07:53.474Z] [2014840]
. 2015-12-07 08:18:38.407 Copying "C:\Users\RE_Queue\Downloads\Queue output\Appeals_2.2.CSV" to remote directory started.
. 2015-12-07 08:18:38.407 Binary transfer mode selected.
. 2015-12-07 08:18:38.407 Checking existence of file.
> 2015-12-07 08:18:38.407 Type: SSH_FXP_LSTAT, Size: 32, Number: 2920199
< 2015-12-07 08:18:38.454 Type: SSH_FXP_ATTRS, Size: 37, Number: 2920199
. 2015-12-07 08:18:38.454 Checking existence of partially transfered file.
> 2015-12-07 08:18:38.454 Type: SSH_FXP_LSTAT, Size: 41, Number: 2920455
< 2015-12-07 08:18:38.485 Type: SSH_FXP_STATUS, Size: 29, Number: 2920455
< 2015-12-07 08:18:38.485 Status code: 2
. 2015-12-07 08:18:38.485 Opening remote file.
> 2015-12-07 08:18:38.485 Type: SSH_FXP_OPEN, Size: 57, Number: 2920707
< 2015-12-07 08:18:38.532 Type: SSH_FXP_HANDLE, Size: 13, Number: 2920707
> 2015-12-07 08:18:38.532 Type: SSH_FXP_WRITE, Size: 32764, Number: 2921222
. 2015-12-07 08:18:38.860 114 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:18:38.860 Type: SSH_FXP_CLOSE, Size: 13, Number: 2937092
< 2015-12-07 08:18:38.860 Type: SSH_FXP_STATUS, Size: 24, Number: 2934790
< 2015-12-07 08:18:38.860 Type: SSH_FXP_STATUS, Size: 24, Number: 2935046
< 2015-12-07 08:18:38.860 Type: SSH_FXP_STATUS, Size: 24, Number: 2935302
< 2015-12-07 08:18:38.891 Type: SSH_FXP_STATUS, Size: 24, Number: 2935558
< 2015-12-07 08:18:38.891 Type: SSH_FXP_STATUS, Size: 24, Number: 2935814
< 2015-12-07 08:18:38.891 Type: SSH_FXP_STATUS, Size: 24, Number: 2936070
< 2015-12-07 08:18:38.891 Type: SSH_FXP_STATUS, Size: 24, Number: 2936326
< 2015-12-07 08:18:38.891 Type: SSH_FXP_STATUS, Size: 24, Number: 2936582
< 2015-12-07 08:18:38.891 Type: SSH_FXP_STATUS, Size: 24, Number: 2936838
< 2015-12-07 08:18:38.938 Type: SSH_FXP_STATUS, Size: 24, Number: 2937092
< 2015-12-07 08:18:38.938 Status code: 0
> 2015-12-07 08:18:38.938 Type: SSH_FXP_REMOVE, Size: 32, Number: 2937357
< 2015-12-07 08:18:38.985 Type: SSH_FXP_STATUS, Size: 24, Number: 2937357
< 2015-12-07 08:18:38.985 Status code: 0
> 2015-12-07 08:18:38.985 Type: SSH_FXP_RENAME, Size: 68, Number: 2937618
< 2015-12-07 08:18:39.016 Type: SSH_FXP_STATUS, Size: 24, Number: 2937618
< 2015-12-07 08:18:39.016 Status code: 0
. 2015-12-07 08:18:39.016 Preserving timestamp [2015-12-04T11:07:53.000Z]
> 2015-12-07 08:18:39.016 Type: SSH_FXP_SETSTAT, Size: 48, Number: 2920969
< 2015-12-07 08:18:39.063 Type: SSH_FXP_STATUS, Size: 24, Number: 2920969
< 2015-12-07 08:18:39.063 Status code: 0
. 2015-12-07 08:18:39.063 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Appeals_2.2.CSV' [2014840]
. 2015-12-07 08:18:39.063 File: 'C:\Users\RE_Queue\Downloads\Queue output\Assignment History_3.5.CSV' [2015-12-04T17:32:23.747Z] [1898766]
. 2015-12-07 08:18:39.265 Copying "C:\Users\RE_Queue\Downloads\Queue output\Assignment History_3.5.CSV" to remote directory started.
. 2015-12-07 08:18:39.265 Binary transfer mode selected.
. 2015-12-07 08:18:39.265 Checking existence of file.
> 2015-12-07 08:18:39.265 Type: SSH_FXP_LSTAT, Size: 43, Number: 2937863
< 2015-12-07 08:18:39.312 Type: SSH_FXP_ATTRS, Size: 37, Number: 2937863
. 2015-12-07 08:18:39.312 Checking existence of partially transfered file.
> 2015-12-07 08:18:39.312 Type: SSH_FXP_LSTAT, Size: 52, Number: 2938119
< 2015-12-07 08:18:39.359 Type: SSH_FXP_STATUS, Size: 29, Number: 2938119
< 2015-12-07 08:18:39.359 Status code: 2
. 2015-12-07 08:18:39.359 Opening remote file.
> 2015-12-07 08:18:39.359 Type: SSH_FXP_OPEN, Size: 68, Number: 2938371
< 2015-12-07 08:18:39.390 Type: SSH_FXP_HANDLE, Size: 13, Number: 2938371
> 2015-12-07 08:18:39.390 Type: SSH_FXP_WRITE, Size: 32764, Number: 2938886
. 2015-12-07 08:18:39.702 106 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:18:39.702 Type: SSH_FXP_CLOSE, Size: 13, Number: 2953732
< 2015-12-07 08:18:39.702 Type: SSH_FXP_STATUS, Size: 24, Number: 2951430
< 2015-12-07 08:18:39.718 Type: SSH_FXP_STATUS, Size: 24, Number: 2951686
< 2015-12-07 08:18:39.718 Type: SSH_FXP_STATUS, Size: 24, Number: 2951942
< 2015-12-07 08:18:39.718 Type: SSH_FXP_STATUS, Size: 24, Number: 2952198
< 2015-12-07 08:18:39.718 Type: SSH_FXP_STATUS, Size: 24, Number: 2952454
< 2015-12-07 08:18:39.718 Type: SSH_FXP_STATUS, Size: 24, Number: 2952710
< 2015-12-07 08:18:39.733 Type: SSH_FXP_STATUS, Size: 24, Number: 2952966
< 2015-12-07 08:18:39.749 Type: SSH_FXP_STATUS, Size: 24, Number: 2953222
< 2015-12-07 08:18:39.749 Type: SSH_FXP_STATUS, Size: 24, Number: 2953478
< 2015-12-07 08:18:39.796 Type: SSH_FXP_STATUS, Size: 24, Number: 2953732
< 2015-12-07 08:18:39.796 Status code: 0
> 2015-12-07 08:18:39.796 Type: SSH_FXP_REMOVE, Size: 43, Number: 2953997
< 2015-12-07 08:18:39.827 Type: SSH_FXP_STATUS, Size: 24, Number: 2953997
< 2015-12-07 08:18:39.827 Status code: 0
> 2015-12-07 08:18:39.827 Type: SSH_FXP_RENAME, Size: 90, Number: 2954258
< 2015-12-07 08:18:39.874 Type: SSH_FXP_STATUS, Size: 24, Number: 2954258
< 2015-12-07 08:18:39.874 Status code: 0
. 2015-12-07 08:18:39.874 Preserving timestamp [2015-12-04T17:32:23.000Z]
> 2015-12-07 08:18:39.874 Type: SSH_FXP_SETSTAT, Size: 59, Number: 2938633
< 2015-12-07 08:18:39.921 Type: SSH_FXP_STATUS, Size: 24, Number: 2938633
< 2015-12-07 08:18:39.921 Status code: 0
. 2015-12-07 08:18:39.921 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Assignment History_3.5.CSV' [1898766]
. 2015-12-07 08:18:39.921 File: 'C:\Users\RE_Queue\Downloads\Queue output\Associated Entities_1.8.CSV' [2015-12-04T19:49:24.154Z] [195698727]
. 2015-12-07 08:18:39.983 Copying "C:\Users\RE_Queue\Downloads\Queue output\Associated Entities_1.8.CSV" to remote directory started.
. 2015-12-07 08:18:39.983 Binary transfer mode selected.
. 2015-12-07 08:18:39.983 Checking existence of file.
> 2015-12-07 08:18:39.983 Type: SSH_FXP_LSTAT, Size: 44, Number: 2954503
< 2015-12-07 08:18:40.014 Type: SSH_FXP_ATTRS, Size: 37, Number: 2954503
. 2015-12-07 08:18:40.014 Checking existence of partially transfered file.
> 2015-12-07 08:18:40.014 Type: SSH_FXP_LSTAT, Size: 53, Number: 2954759
< 2015-12-07 08:18:40.061 Type: SSH_FXP_STATUS, Size: 29, Number: 2954759
< 2015-12-07 08:18:40.061 Status code: 2
. 2015-12-07 08:18:40.061 Opening remote file.
> 2015-12-07 08:18:40.061 Type: SSH_FXP_OPEN, Size: 69, Number: 2955011
< 2015-12-07 08:18:40.108 Type: SSH_FXP_HANDLE, Size: 13, Number: 2955011
> 2015-12-07 08:18:40.108 Type: SSH_FXP_WRITE, Size: 32764, Number: 2955526
. 2015-12-07 08:19:29.987 11946 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:19:29.987 Type: SSH_FXP_CLOSE, Size: 13, Number: 4485892
< 2015-12-07 08:19:29.987 Type: SSH_FXP_STATUS, Size: 24, Number: 4483590
< 2015-12-07 08:19:30.002 Type: SSH_FXP_STATUS, Size: 24, Number: 4483846
< 2015-12-07 08:19:30.002 Type: SSH_FXP_STATUS, Size: 24, Number: 4484102
< 2015-12-07 08:19:30.018 Type: SSH_FXP_STATUS, Size: 24, Number: 4484358
< 2015-12-07 08:19:30.018 Type: SSH_FXP_STATUS, Size: 24, Number: 4484614
< 2015-12-07 08:19:30.018 Type: SSH_FXP_STATUS, Size: 24, Number: 4484870
< 2015-12-07 08:19:30.018 Type: SSH_FXP_STATUS, Size: 24, Number: 4485126
< 2015-12-07 08:19:30.018 Type: SSH_FXP_STATUS, Size: 24, Number: 4485382
< 2015-12-07 08:19:30.033 Type: SSH_FXP_STATUS, Size: 24, Number: 4485638
< 2015-12-07 08:19:30.299 Type: SSH_FXP_STATUS, Size: 24, Number: 4485892
< 2015-12-07 08:19:30.299 Status code: 0
> 2015-12-07 08:19:30.299 Type: SSH_FXP_REMOVE, Size: 44, Number: 4486157
< 2015-12-07 08:19:30.345 Type: SSH_FXP_STATUS, Size: 24, Number: 4486157
< 2015-12-07 08:19:30.345 Status code: 0
> 2015-12-07 08:19:30.345 Type: SSH_FXP_RENAME, Size: 92, Number: 4486418
< 2015-12-07 08:19:30.392 Type: SSH_FXP_STATUS, Size: 24, Number: 4486418
< 2015-12-07 08:19:30.392 Status code: 0
. 2015-12-07 08:19:30.392 Preserving timestamp [2015-12-04T19:49:24.000Z]
> 2015-12-07 08:19:30.392 Type: SSH_FXP_SETSTAT, Size: 60, Number: 2955273
< 2015-12-07 08:19:30.423 Type: SSH_FXP_STATUS, Size: 24, Number: 2955273
< 2015-12-07 08:19:30.423 Status code: 0
. 2015-12-07 08:19:30.423 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Associated Entities_1.8.CSV' [195698727]
. 2015-12-07 08:19:30.423 File: 'C:\Users\RE_Queue\Downloads\Queue output\Associated Entities_1.8_Funds.CSV' [2015-12-04T21:35:21.103Z] [182423552]
. 2015-12-07 08:19:30.501 Copying "C:\Users\RE_Queue\Downloads\Queue output\Associated Entities_1.8_Funds.CSV" to remote directory started.
. 2015-12-07 08:19:30.501 Binary transfer mode selected.
. 2015-12-07 08:19:30.501 Checking existence of file.
> 2015-12-07 08:19:30.501 Type: SSH_FXP_LSTAT, Size: 50, Number: 4486663
< 2015-12-07 08:19:30.548 Type: SSH_FXP_ATTRS, Size: 37, Number: 4486663
. 2015-12-07 08:19:30.548 Checking existence of partially transfered file.
> 2015-12-07 08:19:30.548 Type: SSH_FXP_LSTAT, Size: 59, Number: 4486919
< 2015-12-07 08:19:30.595 Type: SSH_FXP_STATUS, Size: 29, Number: 4486919
< 2015-12-07 08:19:30.595 Status code: 2
. 2015-12-07 08:19:30.595 Opening remote file.
> 2015-12-07 08:19:30.595 Type: SSH_FXP_OPEN, Size: 75, Number: 4487171
< 2015-12-07 08:19:30.626 Type: SSH_FXP_HANDLE, Size: 13, Number: 4487171
> 2015-12-07 08:19:30.626 Type: SSH_FXP_WRITE, Size: 32764, Number: 4487686
. 2015-12-07 08:20:02.204 11135 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:02.204 Type: SSH_FXP_CLOSE, Size: 13, Number: 5914372
< 2015-12-07 08:20:02.204 Type: SSH_FXP_STATUS, Size: 24, Number: 5911814
< 2015-12-07 08:20:02.220 Type: SSH_FXP_STATUS, Size: 24, Number: 5912070
< 2015-12-07 08:20:02.235 Type: SSH_FXP_STATUS, Size: 24, Number: 5912326
< 2015-12-07 08:20:02.235 Type: SSH_FXP_STATUS, Size: 24, Number: 5912582
< 2015-12-07 08:20:02.235 Type: SSH_FXP_STATUS, Size: 24, Number: 5912838
< 2015-12-07 08:20:02.251 Type: SSH_FXP_STATUS, Size: 24, Number: 5913094
< 2015-12-07 08:20:02.251 Type: SSH_FXP_STATUS, Size: 24, Number: 5913350
< 2015-12-07 08:20:02.251 Type: SSH_FXP_STATUS, Size: 24, Number: 5913606
< 2015-12-07 08:20:02.251 Type: SSH_FXP_STATUS, Size: 24, Number: 5913862
< 2015-12-07 08:20:02.266 Type: SSH_FXP_STATUS, Size: 24, Number: 5914118
< 2015-12-07 08:20:02.688 Type: SSH_FXP_STATUS, Size: 24, Number: 5914372
< 2015-12-07 08:20:02.688 Status code: 0
> 2015-12-07 08:20:02.688 Type: SSH_FXP_REMOVE, Size: 50, Number: 5914637
< 2015-12-07 08:20:02.750 Type: SSH_FXP_STATUS, Size: 24, Number: 5914637
< 2015-12-07 08:20:02.750 Status code: 0
> 2015-12-07 08:20:02.750 Type: SSH_FXP_RENAME, Size: 104, Number: 5914898
< 2015-12-07 08:20:02.797 Type: SSH_FXP_STATUS, Size: 24, Number: 5914898
< 2015-12-07 08:20:02.797 Status code: 0
. 2015-12-07 08:20:02.797 Preserving timestamp [2015-12-04T21:35:21.000Z]
> 2015-12-07 08:20:02.797 Type: SSH_FXP_SETSTAT, Size: 66, Number: 4487433
< 2015-12-07 08:20:02.844 Type: SSH_FXP_STATUS, Size: 24, Number: 4487433
< 2015-12-07 08:20:02.844 Status code: 0
. 2015-12-07 08:20:02.844 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Associated Entities_1.8_Funds.CSV' [182423552]
. 2015-12-07 08:20:02.844 File: 'C:\Users\RE_Queue\Downloads\Queue output\Contact Restrictions_1.6.CSV' [2015-12-04T21:40:46.221Z] [10598331]
. 2015-12-07 08:20:03.203 Copying "C:\Users\RE_Queue\Downloads\Queue output\Contact Restrictions_1.6.CSV" to remote directory started.
. 2015-12-07 08:20:03.203 Binary transfer mode selected.
. 2015-12-07 08:20:03.203 Checking existence of file.
> 2015-12-07 08:20:03.203 Type: SSH_FXP_LSTAT, Size: 45, Number: 5915143
< 2015-12-07 08:20:03.234 Type: SSH_FXP_ATTRS, Size: 37, Number: 5915143
. 2015-12-07 08:20:03.234 Checking existence of partially transfered file.
> 2015-12-07 08:20:03.234 Type: SSH_FXP_LSTAT, Size: 54, Number: 5915399
< 2015-12-07 08:20:03.281 Type: SSH_FXP_STATUS, Size: 29, Number: 5915399
< 2015-12-07 08:20:03.281 Status code: 2
. 2015-12-07 08:20:03.281 Opening remote file.
> 2015-12-07 08:20:03.281 Type: SSH_FXP_OPEN, Size: 70, Number: 5915651
< 2015-12-07 08:20:03.327 Type: SSH_FXP_HANDLE, Size: 13, Number: 5915651
> 2015-12-07 08:20:03.327 Type: SSH_FXP_WRITE, Size: 32764, Number: 5916166
. 2015-12-07 08:20:05.090 638 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:05.090 Type: SSH_FXP_CLOSE, Size: 13, Number: 5999108
< 2015-12-07 08:20:05.090 Type: SSH_FXP_STATUS, Size: 24, Number: 5996806
< 2015-12-07 08:20:05.090 Type: SSH_FXP_STATUS, Size: 24, Number: 5997062
< 2015-12-07 08:20:05.090 Type: SSH_FXP_STATUS, Size: 24, Number: 5997318
< 2015-12-07 08:20:05.106 Type: SSH_FXP_STATUS, Size: 24, Number: 5997574
< 2015-12-07 08:20:05.106 Type: SSH_FXP_STATUS, Size: 24, Number: 5997830
< 2015-12-07 08:20:05.122 Type: SSH_FXP_STATUS, Size: 24, Number: 5998086
< 2015-12-07 08:20:05.137 Type: SSH_FXP_STATUS, Size: 24, Number: 5998342
< 2015-12-07 08:20:05.137 Type: SSH_FXP_STATUS, Size: 24, Number: 5998598
< 2015-12-07 08:20:05.137 Type: SSH_FXP_STATUS, Size: 24, Number: 5998854
< 2015-12-07 08:20:05.340 Type: SSH_FXP_STATUS, Size: 24, Number: 5999108
< 2015-12-07 08:20:05.340 Status code: 0
> 2015-12-07 08:20:05.340 Type: SSH_FXP_REMOVE, Size: 45, Number: 5999373
< 2015-12-07 08:20:05.387 Type: SSH_FXP_STATUS, Size: 24, Number: 5999373
< 2015-12-07 08:20:05.387 Status code: 0
> 2015-12-07 08:20:05.387 Type: SSH_FXP_RENAME, Size: 94, Number: 5999634
< 2015-12-07 08:20:05.434 Type: SSH_FXP_STATUS, Size: 24, Number: 5999634
< 2015-12-07 08:20:05.434 Status code: 0
. 2015-12-07 08:20:05.434 Preserving timestamp [2015-12-04T21:40:46.000Z]
> 2015-12-07 08:20:05.434 Type: SSH_FXP_SETSTAT, Size: 61, Number: 5915913
< 2015-12-07 08:20:05.465 Type: SSH_FXP_STATUS, Size: 24, Number: 5915913
< 2015-12-07 08:20:05.465 Status code: 0
. 2015-12-07 08:20:05.465 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Contact Restrictions_1.6.CSV' [10598331]
. 2015-12-07 08:20:05.480 File: 'C:\Users\RE_Queue\Downloads\Queue output\Customer Specific Codes_4.2.CSV' [2015-12-04T22:43:40.987Z] [65158693]
. 2015-12-07 08:20:05.527 Copying "C:\Users\RE_Queue\Downloads\Queue output\Customer Specific Codes_4.2.CSV" to remote directory started.
. 2015-12-07 08:20:05.527 Binary transfer mode selected.
. 2015-12-07 08:20:05.527 Checking existence of file.
> 2015-12-07 08:20:05.527 Type: SSH_FXP_LSTAT, Size: 48, Number: 5999879
< 2015-12-07 08:20:05.574 Type: SSH_FXP_ATTRS, Size: 37, Number: 5999879
. 2015-12-07 08:20:05.574 Checking existence of partially transfered file.
> 2015-12-07 08:20:05.574 Type: SSH_FXP_LSTAT, Size: 57, Number: 6000135
< 2015-12-07 08:20:05.621 Type: SSH_FXP_STATUS, Size: 29, Number: 6000135
< 2015-12-07 08:20:05.621 Status code: 2
. 2015-12-07 08:20:05.621 Opening remote file.
> 2015-12-07 08:20:05.621 Type: SSH_FXP_OPEN, Size: 73, Number: 6000387
< 2015-12-07 08:20:05.652 Type: SSH_FXP_HANDLE, Size: 13, Number: 6000387
> 2015-12-07 08:20:05.652 Type: SSH_FXP_WRITE, Size: 32764, Number: 6000902
. 2015-12-07 08:20:23.797 3972 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:23.797 Type: SSH_FXP_CLOSE, Size: 13, Number: 6510596
< 2015-12-07 08:20:23.797 Type: SSH_FXP_STATUS, Size: 24, Number: 6508294
< 2015-12-07 08:20:23.812 Type: SSH_FXP_STATUS, Size: 24, Number: 6508550
< 2015-12-07 08:20:23.812 Type: SSH_FXP_STATUS, Size: 24, Number: 6508806
< 2015-12-07 08:20:23.812 Type: SSH_FXP_STATUS, Size: 24, Number: 6509062
< 2015-12-07 08:20:23.812 Type: SSH_FXP_STATUS, Size: 24, Number: 6509318
< 2015-12-07 08:20:23.844 Type: SSH_FXP_STATUS, Size: 24, Number: 6509574
< 2015-12-07 08:20:23.844 Type: SSH_FXP_STATUS, Size: 24, Number: 6509830
< 2015-12-07 08:20:23.844 Type: SSH_FXP_STATUS, Size: 24, Number: 6510086
< 2015-12-07 08:20:23.844 Type: SSH_FXP_STATUS, Size: 24, Number: 6510342
< 2015-12-07 08:20:24.171 Type: SSH_FXP_STATUS, Size: 24, Number: 6510596
< 2015-12-07 08:20:24.171 Status code: 0
> 2015-12-07 08:20:24.171 Type: SSH_FXP_REMOVE, Size: 48, Number: 6510861
< 2015-12-07 08:20:24.218 Type: SSH_FXP_STATUS, Size: 24, Number: 6510861
< 2015-12-07 08:20:24.218 Status code: 0
> 2015-12-07 08:20:24.218 Type: SSH_FXP_RENAME, Size: 100, Number: 6511122
< 2015-12-07 08:20:24.265 Type: SSH_FXP_STATUS, Size: 24, Number: 6511122
< 2015-12-07 08:20:24.265 Status code: 0
. 2015-12-07 08:20:24.265 Preserving timestamp [2015-12-04T22:43:40.000Z]
> 2015-12-07 08:20:24.265 Type: SSH_FXP_SETSTAT, Size: 64, Number: 6000649
< 2015-12-07 08:20:24.296 Type: SSH_FXP_STATUS, Size: 24, Number: 6000649
< 2015-12-07 08:20:24.296 Status code: 0
. 2015-12-07 08:20:24.296 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Customer Specific Codes_4.2.CSV' [65158693]
. 2015-12-07 08:20:24.296 File: 'C:\Users\RE_Queue\Downloads\Queue output\Degrees_1.3.CSV' [2015-12-03T23:01:46.582Z] [18321020]
. 2015-12-07 08:20:24.374 Copying "C:\Users\RE_Queue\Downloads\Queue output\Degrees_1.3.CSV" to remote directory started.
. 2015-12-07 08:20:24.374 Binary transfer mode selected.
. 2015-12-07 08:20:24.374 Checking existence of file.
> 2015-12-07 08:20:24.374 Type: SSH_FXP_LSTAT, Size: 32, Number: 6511367
< 2015-12-07 08:20:24.421 Type: SSH_FXP_ATTRS, Size: 37, Number: 6511367
. 2015-12-07 08:20:24.421 Checking existence of partially transfered file.
> 2015-12-07 08:20:24.421 Type: SSH_FXP_LSTAT, Size: 41, Number: 6511623
< 2015-12-07 08:20:24.468 Type: SSH_FXP_STATUS, Size: 29, Number: 6511623
< 2015-12-07 08:20:24.468 Status code: 2
. 2015-12-07 08:20:24.468 Opening remote file.
> 2015-12-07 08:20:24.468 Type: SSH_FXP_OPEN, Size: 57, Number: 6511875
< 2015-12-07 08:20:24.499 Type: SSH_FXP_HANDLE, Size: 13, Number: 6511875
> 2015-12-07 08:20:24.499 Type: SSH_FXP_WRITE, Size: 32764, Number: 6512390
. 2015-12-07 08:20:27.572 1110 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:27.572 Type: SSH_FXP_CLOSE, Size: 13, Number: 6655748
< 2015-12-07 08:20:27.588 Type: SSH_FXP_STATUS, Size: 24, Number: 6653446
< 2015-12-07 08:20:27.588 Type: SSH_FXP_STATUS, Size: 24, Number: 6653702
< 2015-12-07 08:20:27.588 Type: SSH_FXP_STATUS, Size: 24, Number: 6653958
< 2015-12-07 08:20:27.588 Type: SSH_FXP_STATUS, Size: 24, Number: 6654214
< 2015-12-07 08:20:27.588 Type: SSH_FXP_STATUS, Size: 24, Number: 6654470
< 2015-12-07 08:20:27.604 Type: SSH_FXP_STATUS, Size: 24, Number: 6654726
< 2015-12-07 08:20:27.604 Type: SSH_FXP_STATUS, Size: 24, Number: 6654982
< 2015-12-07 08:20:27.619 Type: SSH_FXP_STATUS, Size: 24, Number: 6655238
< 2015-12-07 08:20:27.619 Type: SSH_FXP_STATUS, Size: 24, Number: 6655494
< 2015-12-07 08:20:27.978 Type: SSH_FXP_STATUS, Size: 24, Number: 6655748
< 2015-12-07 08:20:27.978 Status code: 0
> 2015-12-07 08:20:27.978 Type: SSH_FXP_REMOVE, Size: 32, Number: 6656013
< 2015-12-07 08:20:28.056 Type: SSH_FXP_STATUS, Size: 24, Number: 6656013
< 2015-12-07 08:20:28.056 Status code: 0
> 2015-12-07 08:20:28.056 Type: SSH_FXP_RENAME, Size: 68, Number: 6656274
< 2015-12-07 08:20:28.103 Type: SSH_FXP_STATUS, Size: 24, Number: 6656274
< 2015-12-07 08:20:28.103 Status code: 0
. 2015-12-07 08:20:28.103 Preserving timestamp [2015-12-03T23:01:46.000Z]
> 2015-12-07 08:20:28.103 Type: SSH_FXP_SETSTAT, Size: 48, Number: 6512137
< 2015-12-07 08:20:28.134 Type: SSH_FXP_STATUS, Size: 24, Number: 6512137
< 2015-12-07 08:20:28.134 Status code: 0
. 2015-12-07 08:20:28.134 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Degrees_1.3.CSV' [18321020]
. 2015-12-07 08:20:28.150 File: 'C:\Users\RE_Queue\Downloads\Queue output\Donor Trans History_2.1.CSV' [2015-12-07T13:20:28.072Z] [62763316]
. 2015-12-07 08:20:28.150 Copying "C:\Users\RE_Queue\Downloads\Queue output\Donor Trans History_2.1.CSV" to remote directory started.
. 2015-12-07 08:20:28.150 Binary transfer mode selected.
. 2015-12-07 08:20:28.150 Checking existence of file.
> 2015-12-07 08:20:28.150 Type: SSH_FXP_LSTAT, Size: 44, Number: 6656519
< 2015-12-07 08:20:28.181 Type: SSH_FXP_ATTRS, Size: 37, Number: 6656519
. 2015-12-07 08:20:28.181 Checking existence of partially transfered file.
> 2015-12-07 08:20:28.181 Type: SSH_FXP_LSTAT, Size: 53, Number: 6656775
< 2015-12-07 08:20:28.228 Type: SSH_FXP_STATUS, Size: 29, Number: 6656775
< 2015-12-07 08:20:28.228 Status code: 2
. 2015-12-07 08:20:28.228 Opening remote file.
> 2015-12-07 08:20:28.228 Type: SSH_FXP_OPEN, Size: 69, Number: 6657027
< 2015-12-07 08:20:28.274 Type: SSH_FXP_HANDLE, Size: 13, Number: 6657027
> 2015-12-07 08:20:28.274 Type: SSH_FXP_WRITE, Size: 32764, Number: 6657542
. 2015-12-07 08:20:39.258 3831 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:39.258 Type: SSH_FXP_CLOSE, Size: 13, Number: 7149316
< 2015-12-07 08:20:39.258 Type: SSH_FXP_STATUS, Size: 24, Number: 7146758
< 2015-12-07 08:20:39.258 Type: SSH_FXP_STATUS, Size: 24, Number: 7147014
< 2015-12-07 08:20:39.274 Type: SSH_FXP_STATUS, Size: 24, Number: 7147270
< 2015-12-07 08:20:39.274 Type: SSH_FXP_STATUS, Size: 24, Number: 7147526
< 2015-12-07 08:20:39.289 Type: SSH_FXP_STATUS, Size: 24, Number: 7147782
< 2015-12-07 08:20:39.289 Type: SSH_FXP_STATUS, Size: 24, Number: 7148038
< 2015-12-07 08:20:39.289 Type: SSH_FXP_STATUS, Size: 24, Number: 7148294
< 2015-12-07 08:20:39.289 Type: SSH_FXP_STATUS, Size: 24, Number: 7148550
< 2015-12-07 08:20:39.289 Type: SSH_FXP_STATUS, Size: 24, Number: 7148806
< 2015-12-07 08:20:39.305 Type: SSH_FXP_STATUS, Size: 24, Number: 7149062
< 2015-12-07 08:20:39.742 Type: SSH_FXP_STATUS, Size: 24, Number: 7149316
< 2015-12-07 08:20:39.742 Status code: 0
> 2015-12-07 08:20:39.742 Type: SSH_FXP_REMOVE, Size: 44, Number: 7149581
< 2015-12-07 08:20:39.773 Type: SSH_FXP_STATUS, Size: 24, Number: 7149581
< 2015-12-07 08:20:39.773 Status code: 0
> 2015-12-07 08:20:39.773 Type: SSH_FXP_RENAME, Size: 92, Number: 7149842
< 2015-12-07 08:20:39.820 Type: SSH_FXP_STATUS, Size: 24, Number: 7149842
< 2015-12-07 08:20:39.820 Status code: 0
. 2015-12-07 08:20:39.820 Preserving timestamp [2015-12-07T13:20:28.000Z]
> 2015-12-07 08:20:39.820 Type: SSH_FXP_SETSTAT, Size: 60, Number: 6657289
< 2015-12-07 08:20:39.867 Type: SSH_FXP_STATUS, Size: 24, Number: 6657289
< 2015-12-07 08:20:39.867 Status code: 0
. 2015-12-07 08:20:39.867 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Donor Trans History_2.1.CSV' [62866228]
. 2015-12-07 08:20:39.867 File: 'C:\Users\RE_Queue\Downloads\Queue output\Entity 1.1_Social Media.CSV' [2015-12-03T23:02:07.985Z] [40416]
. 2015-12-07 08:20:39.882 Copying "C:\Users\RE_Queue\Downloads\Queue output\Entity 1.1_Social Media.CSV" to remote directory started.
. 2015-12-07 08:20:39.882 Binary transfer mode selected.
. 2015-12-07 08:20:39.882 Opening remote file.
> 2015-12-07 08:20:39.882 Type: SSH_FXP_OPEN, Size: 60, Number: 7150083
< 2015-12-07 08:20:39.929 Type: SSH_FXP_HANDLE, Size: 13, Number: 7150083
> 2015-12-07 08:20:39.929 Type: SSH_FXP_WRITE, Size: 32764, Number: 7150598
. 2015-12-07 08:20:39.929 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:39.929 Type: SSH_FXP_CLOSE, Size: 13, Number: 7151108
> 2015-12-07 08:20:39.929 Type: SSH_FXP_SETSTAT, Size: 56, Number: 7150345
< 2015-12-07 08:20:39.976 Type: SSH_FXP_STATUS, Size: 24, Number: 7150598
< 2015-12-07 08:20:39.976 Type: SSH_FXP_STATUS, Size: 24, Number: 7150854
< 2015-12-07 08:20:40.007 Type: SSH_FXP_STATUS, Size: 24, Number: 7151108
< 2015-12-07 08:20:40.007 Status code: 0
. 2015-12-07 08:20:40.007 Preserving timestamp [2015-12-03T23:02:07.000Z]
< 2015-12-07 08:20:40.007 Type: SSH_FXP_STATUS, Size: 24, Number: 7150345
. 2015-12-07 08:20:40.007 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Entity 1.1_Social Media.CSV' [40416]
. 2015-12-07 08:20:40.007 File: 'C:\Users\RE_Queue\Downloads\Queue output\Entity_1.1.CSV' [2015-12-04T03:13:09.621Z] [52998546]
. 2015-12-07 08:20:40.038 Copying "C:\Users\RE_Queue\Downloads\Queue output\Entity_1.1.CSV" to remote directory started.
. 2015-12-07 08:20:40.038 Binary transfer mode selected.
. 2015-12-07 08:20:40.038 Checking existence of file.
> 2015-12-07 08:20:40.038 Type: SSH_FXP_LSTAT, Size: 31, Number: 7151367
< 2015-12-07 08:20:40.085 Type: SSH_FXP_ATTRS, Size: 37, Number: 7151367
. 2015-12-07 08:20:40.085 Checking existence of partially transfered file.
> 2015-12-07 08:20:40.085 Type: SSH_FXP_LSTAT, Size: 40, Number: 7151623
< 2015-12-07 08:20:40.116 Type: SSH_FXP_STATUS, Size: 29, Number: 7151623
< 2015-12-07 08:20:40.116 Status code: 2
. 2015-12-07 08:20:40.116 Opening remote file.
> 2015-12-07 08:20:40.116 Type: SSH_FXP_OPEN, Size: 56, Number: 7151875
< 2015-12-07 08:20:40.179 Type: SSH_FXP_HANDLE, Size: 13, Number: 7151875
> 2015-12-07 08:20:40.179 Type: SSH_FXP_WRITE, Size: 32764, Number: 7152390
. 2015-12-07 08:20:57.294 3228 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:57.294 Type: SSH_FXP_CLOSE, Size: 13, Number: 7566852
< 2015-12-07 08:20:57.294 Type: SSH_FXP_STATUS, Size: 24, Number: 7564550
< 2015-12-07 08:20:57.294 Type: SSH_FXP_STATUS, Size: 24, Number: 7564806
< 2015-12-07 08:20:57.294 Type: SSH_FXP_STATUS, Size: 24, Number: 7565062
< 2015-12-07 08:20:57.309 Type: SSH_FXP_STATUS, Size: 24, Number: 7565318
< 2015-12-07 08:20:57.325 Type: SSH_FXP_STATUS, Size: 24, Number: 7565574
< 2015-12-07 08:20:57.325 Type: SSH_FXP_STATUS, Size: 24, Number: 7565830
< 2015-12-07 08:20:57.325 Type: SSH_FXP_STATUS, Size: 24, Number: 7566086
< 2015-12-07 08:20:57.340 Type: SSH_FXP_STATUS, Size: 24, Number: 7566342
< 2015-12-07 08:20:57.340 Type: SSH_FXP_STATUS, Size: 24, Number: 7566598
< 2015-12-07 08:20:57.887 Type: SSH_FXP_STATUS, Size: 24, Number: 7566852
< 2015-12-07 08:20:57.887 Status code: 0
> 2015-12-07 08:20:57.887 Type: SSH_FXP_REMOVE, Size: 31, Number: 7567117
< 2015-12-07 08:20:57.933 Type: SSH_FXP_STATUS, Size: 24, Number: 7567117
< 2015-12-07 08:20:57.933 Status code: 0
> 2015-12-07 08:20:57.933 Type: SSH_FXP_RENAME, Size: 66, Number: 7567378
< 2015-12-07 08:20:57.980 Type: SSH_FXP_STATUS, Size: 24, Number: 7567378
< 2015-12-07 08:20:57.980 Status code: 0
. 2015-12-07 08:20:57.980 Preserving timestamp [2015-12-04T03:13:09.000Z]
> 2015-12-07 08:20:57.980 Type: SSH_FXP_SETSTAT, Size: 47, Number: 7152137
< 2015-12-07 08:20:58.011 Type: SSH_FXP_STATUS, Size: 24, Number: 7152137
< 2015-12-07 08:20:58.011 Status code: 0
. 2015-12-07 08:20:58.011 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Entity_1.1.CSV' [52998546]
. 2015-12-07 08:20:58.027 File: 'C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5.CSV' [2015-12-07T10:46:18.200Z] [1483989]
. 2015-12-07 08:20:58.027 Copying "C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5.CSV" to remote directory started.
. 2015-12-07 08:20:58.027 Binary transfer mode selected.
. 2015-12-07 08:20:58.027 Checking existence of file.
> 2015-12-07 08:20:58.027 Type: SSH_FXP_LSTAT, Size: 46, Number: 7567623
< 2015-12-07 08:20:58.058 Type: SSH_FXP_ATTRS, Size: 37, Number: 7567623
. 2015-12-07 08:20:58.058 Checking existence of partially transfered file.
> 2015-12-07 08:20:58.058 Type: SSH_FXP_LSTAT, Size: 55, Number: 7567879
< 2015-12-07 08:20:58.105 Type: SSH_FXP_STATUS, Size: 29, Number: 7567879
< 2015-12-07 08:20:58.105 Status code: 2
. 2015-12-07 08:20:58.105 Opening remote file.
> 2015-12-07 08:20:58.105 Type: SSH_FXP_OPEN, Size: 71, Number: 7568131
< 2015-12-07 08:20:58.152 Type: SSH_FXP_HANDLE, Size: 13, Number: 7568131
> 2015-12-07 08:20:58.152 Type: SSH_FXP_WRITE, Size: 32764, Number: 7568646
. 2015-12-07 08:20:58.386 82 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:58.386 Type: SSH_FXP_CLOSE, Size: 13, Number: 7580420
< 2015-12-07 08:20:58.386 Type: SSH_FXP_STATUS, Size: 24, Number: 7578118
< 2015-12-07 08:20:58.386 Type: SSH_FXP_STATUS, Size: 24, Number: 7578374
< 2015-12-07 08:20:58.386 Type: SSH_FXP_STATUS, Size: 24, Number: 7578630
< 2015-12-07 08:20:58.417 Type: SSH_FXP_STATUS, Size: 24, Number: 7578886
< 2015-12-07 08:20:58.417 Type: SSH_FXP_STATUS, Size: 24, Number: 7579142
< 2015-12-07 08:20:58.417 Type: SSH_FXP_STATUS, Size: 24, Number: 7579398
< 2015-12-07 08:20:58.417 Type: SSH_FXP_STATUS, Size: 24, Number: 7579654
< 2015-12-07 08:20:58.417 Type: SSH_FXP_STATUS, Size: 24, Number: 7579910
< 2015-12-07 08:20:58.433 Type: SSH_FXP_STATUS, Size: 24, Number: 7580166
< 2015-12-07 08:20:58.448 Type: SSH_FXP_STATUS, Size: 24, Number: 7580420
< 2015-12-07 08:20:58.448 Status code: 0
> 2015-12-07 08:20:58.448 Type: SSH_FXP_REMOVE, Size: 46, Number: 7580685
< 2015-12-07 08:20:58.495 Type: SSH_FXP_STATUS, Size: 24, Number: 7580685
< 2015-12-07 08:20:58.495 Status code: 0
> 2015-12-07 08:20:58.495 Type: SSH_FXP_RENAME, Size: 96, Number: 7580946
< 2015-12-07 08:20:58.542 Type: SSH_FXP_STATUS, Size: 24, Number: 7580946
< 2015-12-07 08:20:58.542 Status code: 0
. 2015-12-07 08:20:58.542 Preserving timestamp [2015-12-07T10:46:18.000Z]
> 2015-12-07 08:20:58.542 Type: SSH_FXP_SETSTAT, Size: 62, Number: 7568393
< 2015-12-07 08:20:58.573 Type: SSH_FXP_STATUS, Size: 24, Number: 7568393
< 2015-12-07 08:20:58.573 Status code: 0
. 2015-12-07 08:20:58.573 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5.CSV' [1483989]
. 2015-12-07 08:20:58.589 File: 'C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5_Event Attendees.CSV' [2015-12-07T11:18:41.859Z] [3078713]
. 2015-12-07 08:20:58.589 Copying "C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5_Event Attendees.CSV" to remote directory started.
. 2015-12-07 08:20:58.589 Binary transfer mode selected.
. 2015-12-07 08:20:58.589 Checking existence of file.
> 2015-12-07 08:20:58.589 Type: SSH_FXP_LSTAT, Size: 62, Number: 7581191
< 2015-12-07 08:20:58.620 Type: SSH_FXP_ATTRS, Size: 37, Number: 7581191
. 2015-12-07 08:20:58.620 Checking existence of partially transfered file.
> 2015-12-07 08:20:58.620 Type: SSH_FXP_LSTAT, Size: 71, Number: 7581447
< 2015-12-07 08:20:58.667 Type: SSH_FXP_STATUS, Size: 29, Number: 7581447
< 2015-12-07 08:20:58.667 Status code: 2
. 2015-12-07 08:20:58.667 Opening remote file.
> 2015-12-07 08:20:58.667 Type: SSH_FXP_OPEN, Size: 87, Number: 7581699
< 2015-12-07 08:20:58.713 Type: SSH_FXP_HANDLE, Size: 13, Number: 7581699
> 2015-12-07 08:20:58.713 Type: SSH_FXP_WRITE, Size: 32764, Number: 7582214
. 2015-12-07 08:20:59.213 179 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:20:59.213 Type: SSH_FXP_CLOSE, Size: 13, Number: 7606532
< 2015-12-07 08:20:59.213 Type: SSH_FXP_STATUS, Size: 24, Number: 7603974
< 2015-12-07 08:20:59.213 Type: SSH_FXP_STATUS, Size: 24, Number: 7604230
< 2015-12-07 08:20:59.213 Type: SSH_FXP_STATUS, Size: 24, Number: 7604486
< 2015-12-07 08:20:59.228 Type: SSH_FXP_STATUS, Size: 24, Number: 7604742
< 2015-12-07 08:20:59.244 Type: SSH_FXP_STATUS, Size: 24, Number: 7604998
< 2015-12-07 08:20:59.244 Type: SSH_FXP_STATUS, Size: 24, Number: 7605254
< 2015-12-07 08:20:59.244 Type: SSH_FXP_STATUS, Size: 24, Number: 7605510
< 2015-12-07 08:20:59.244 Type: SSH_FXP_STATUS, Size: 24, Number: 7605766
< 2015-12-07 08:20:59.259 Type: SSH_FXP_STATUS, Size: 24, Number: 7606022
< 2015-12-07 08:20:59.259 Type: SSH_FXP_STATUS, Size: 24, Number: 7606278
< 2015-12-07 08:20:59.322 Type: SSH_FXP_STATUS, Size: 24, Number: 7606532
< 2015-12-07 08:20:59.322 Status code: 0
> 2015-12-07 08:20:59.322 Type: SSH_FXP_REMOVE, Size: 62, Number: 7606797
< 2015-12-07 08:20:59.353 Type: SSH_FXP_STATUS, Size: 24, Number: 7606797
< 2015-12-07 08:20:59.353 Status code: 0
> 2015-12-07 08:20:59.353 Type: SSH_FXP_RENAME, Size: 128, Number: 7607058
< 2015-12-07 08:20:59.400 Type: SSH_FXP_STATUS, Size: 24, Number: 7607058
< 2015-12-07 08:20:59.400 Status code: 0
. 2015-12-07 08:20:59.400 Preserving timestamp [2015-12-07T11:18:41.000Z]
> 2015-12-07 08:20:59.400 Type: SSH_FXP_SETSTAT, Size: 78, Number: 7581961
< 2015-12-07 08:20:59.447 Type: SSH_FXP_STATUS, Size: 24, Number: 7581961
< 2015-12-07 08:20:59.447 Status code: 0
. 2015-12-07 08:20:59.447 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5_Event Attendees.CSV' [3078713]
. 2015-12-07 08:20:59.447 File: 'C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5_Student Activities.CSV' [2015-12-07T11:19:37.833Z] [3637947]
. 2015-12-07 08:20:59.447 Copying "C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5_Student Activities.CSV" to remote directory started.
. 2015-12-07 08:20:59.447 Binary transfer mode selected.
. 2015-12-07 08:20:59.447 Checking existence of file.
> 2015-12-07 08:20:59.447 Type: SSH_FXP_LSTAT, Size: 65, Number: 7607303
< 2015-12-07 08:20:59.494 Type: SSH_FXP_ATTRS, Size: 37, Number: 7607303
. 2015-12-07 08:20:59.494 Checking existence of partially transfered file.
> 2015-12-07 08:20:59.494 Type: SSH_FXP_LSTAT, Size: 74, Number: 7607559
< 2015-12-07 08:20:59.525 Type: SSH_FXP_STATUS, Size: 29, Number: 7607559
< 2015-12-07 08:20:59.525 Status code: 2
. 2015-12-07 08:20:59.525 Opening remote file.
> 2015-12-07 08:20:59.525 Type: SSH_FXP_OPEN, Size: 90, Number: 7607811
< 2015-12-07 08:20:59.572 Type: SSH_FXP_HANDLE, Size: 13, Number: 7607811
> 2015-12-07 08:20:59.572 Type: SSH_FXP_WRITE, Size: 32764, Number: 7608326
. 2015-12-07 08:21:00.164 213 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:21:00.164 Type: SSH_FXP_CLOSE, Size: 13, Number: 7636996
< 2015-12-07 08:21:00.164 Type: SSH_FXP_STATUS, Size: 24, Number: 7634438
< 2015-12-07 08:21:00.164 Type: SSH_FXP_STATUS, Size: 24, Number: 7634694
< 2015-12-07 08:21:00.196 Type: SSH_FXP_STATUS, Size: 24, Number: 7634950
< 2015-12-07 08:21:00.196 Type: SSH_FXP_STATUS, Size: 24, Number: 7635206
< 2015-12-07 08:21:00.196 Type: SSH_FXP_STATUS, Size: 24, Number: 7635462
< 2015-12-07 08:21:00.196 Type: SSH_FXP_STATUS, Size: 24, Number: 7635718
< 2015-12-07 08:21:00.196 Type: SSH_FXP_STATUS, Size: 24, Number: 7635974
< 2015-12-07 08:21:00.196 Type: SSH_FXP_STATUS, Size: 24, Number: 7636230
< 2015-12-07 08:21:00.211 Type: SSH_FXP_STATUS, Size: 24, Number: 7636486
< 2015-12-07 08:21:00.211 Type: SSH_FXP_STATUS, Size: 24, Number: 7636742
< 2015-12-07 08:21:00.305 Type: SSH_FXP_STATUS, Size: 24, Number: 7636996
< 2015-12-07 08:21:00.305 Status code: 0
> 2015-12-07 08:21:00.305 Type: SSH_FXP_REMOVE, Size: 65, Number: 7637261
< 2015-12-07 08:21:00.352 Type: SSH_FXP_STATUS, Size: 24, Number: 7637261
< 2015-12-07 08:21:00.352 Status code: 0
> 2015-12-07 08:21:00.352 Type: SSH_FXP_RENAME, Size: 134, Number: 7637522
< 2015-12-07 08:21:00.398 Type: SSH_FXP_STATUS, Size: 24, Number: 7637522
< 2015-12-07 08:21:00.398 Status code: 0
. 2015-12-07 08:21:00.398 Preserving timestamp [2015-12-07T11:19:37.000Z]
> 2015-12-07 08:21:00.398 Type: SSH_FXP_SETSTAT, Size: 81, Number: 7608073
< 2015-12-07 08:21:00.445 Type: SSH_FXP_STATUS, Size: 24, Number: 7608073
< 2015-12-07 08:21:00.445 Status code: 0
. 2015-12-07 08:21:00.445 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Participation History_1.5_Student Activities.CSV' [3637947]
. 2015-12-07 08:21:00.445 File: 'C:\Users\RE_Queue\Downloads\Queue output\Proposal Assignment_3.7.CSV' [2015-12-07T11:20:45.710Z] [27205]
. 2015-12-07 08:21:00.445 Copying "C:\Users\RE_Queue\Downloads\Queue output\Proposal Assignment_3.7.CSV" to remote directory started.
. 2015-12-07 08:21:00.445 Binary transfer mode selected.
. 2015-12-07 08:21:00.445 Opening remote file.
> 2015-12-07 08:21:00.445 Type: SSH_FXP_OPEN, Size: 60, Number: 7637763
< 2015-12-07 08:21:00.492 Type: SSH_FXP_HANDLE, Size: 13, Number: 7637763
> 2015-12-07 08:21:00.492 Type: SSH_FXP_WRITE, Size: 27230, Number: 7638278
> 2015-12-07 08:21:00.492 Type: SSH_FXP_CLOSE, Size: 13, Number: 7638532
> 2015-12-07 08:21:00.492 Type: SSH_FXP_SETSTAT, Size: 56, Number: 7638025
< 2015-12-07 08:21:00.539 Type: SSH_FXP_STATUS, Size: 24, Number: 7638278
< 2015-12-07 08:21:00.570 Type: SSH_FXP_STATUS, Size: 24, Number: 7638532
< 2015-12-07 08:21:00.570 Status code: 0
. 2015-12-07 08:21:00.570 Preserving timestamp [2015-12-07T11:20:45.000Z]
< 2015-12-07 08:21:00.570 Type: SSH_FXP_STATUS, Size: 24, Number: 7638025
. 2015-12-07 08:21:00.570 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Proposal Assignment_3.7.CSV' [27205]
. 2015-12-07 08:21:00.570 File: 'C:\Users\RE_Queue\Downloads\Queue output\Proposal_3.6.CSV' [2015-12-07T11:20:49.579Z] [147608]
. 2015-12-07 08:21:00.570 Copying "C:\Users\RE_Queue\Downloads\Queue output\Proposal_3.6.CSV" to remote directory started.
. 2015-12-07 08:21:00.570 Binary transfer mode selected.
. 2015-12-07 08:21:00.570 Checking existence of file.
> 2015-12-07 08:21:00.570 Type: SSH_FXP_LSTAT, Size: 33, Number: 7638791
< 2015-12-07 08:21:00.617 Type: SSH_FXP_ATTRS, Size: 37, Number: 7638791
. 2015-12-07 08:21:00.617 Checking existence of partially transfered file.
> 2015-12-07 08:21:00.617 Type: SSH_FXP_LSTAT, Size: 42, Number: 7639047
< 2015-12-07 08:21:00.664 Type: SSH_FXP_STATUS, Size: 29, Number: 7639047
< 2015-12-07 08:21:00.664 Status code: 2
. 2015-12-07 08:21:00.664 Opening remote file.
> 2015-12-07 08:21:00.664 Type: SSH_FXP_OPEN, Size: 58, Number: 7639299
< 2015-12-07 08:21:00.695 Type: SSH_FXP_HANDLE, Size: 13, Number: 7639299
> 2015-12-07 08:21:00.710 Type: SSH_FXP_WRITE, Size: 32764, Number: 7639814
. 2015-12-07 08:21:00.710 4 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:21:00.710 Type: SSH_FXP_CLOSE, Size: 13, Number: 7641092
< 2015-12-07 08:21:00.742 Type: SSH_FXP_STATUS, Size: 24, Number: 7639814
< 2015-12-07 08:21:00.757 Type: SSH_FXP_STATUS, Size: 24, Number: 7640070
< 2015-12-07 08:21:00.757 Type: SSH_FXP_STATUS, Size: 24, Number: 7640326
< 2015-12-07 08:21:00.757 Type: SSH_FXP_STATUS, Size: 24, Number: 7640582
< 2015-12-07 08:21:00.757 Type: SSH_FXP_STATUS, Size: 24, Number: 7640838
< 2015-12-07 08:21:00.788 Type: SSH_FXP_STATUS, Size: 24, Number: 7641092
< 2015-12-07 08:21:00.788 Status code: 0
> 2015-12-07 08:21:00.788 Type: SSH_FXP_REMOVE, Size: 33, Number: 7641357
< 2015-12-07 08:21:00.835 Type: SSH_FXP_STATUS, Size: 24, Number: 7641357
< 2015-12-07 08:21:00.835 Status code: 0
> 2015-12-07 08:21:00.835 Type: SSH_FXP_RENAME, Size: 70, Number: 7641618
< 2015-12-07 08:21:00.866 Type: SSH_FXP_STATUS, Size: 24, Number: 7641618
< 2015-12-07 08:21:00.866 Status code: 0
. 2015-12-07 08:21:00.866 Preserving timestamp [2015-12-07T11:20:49.000Z]
> 2015-12-07 08:21:00.866 Type: SSH_FXP_SETSTAT, Size: 49, Number: 7639561
< 2015-12-07 08:21:00.913 Type: SSH_FXP_STATUS, Size: 24, Number: 7639561
< 2015-12-07 08:21:00.913 Status code: 0
. 2015-12-07 08:21:00.913 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Proposal_3.6.CSV' [147608]
. 2015-12-07 08:21:00.913 File: 'C:\Users\RE_Queue\Downloads\Queue output\Prospect Status_3.4.CSV' [2015-12-07T11:33:52.391Z] [18343887]
. 2015-12-07 08:21:00.913 Copying "C:\Users\RE_Queue\Downloads\Queue output\Prospect Status_3.4.CSV" to remote directory started.
. 2015-12-07 08:21:00.913 Binary transfer mode selected.
. 2015-12-07 08:21:00.913 Checking existence of file.
> 2015-12-07 08:21:00.913 Type: SSH_FXP_LSTAT, Size: 40, Number: 7641863
< 2015-12-07 08:21:00.960 Type: SSH_FXP_ATTRS, Size: 37, Number: 7641863
. 2015-12-07 08:21:00.960 Checking existence of partially transfered file.
> 2015-12-07 08:21:00.960 Type: SSH_FXP_LSTAT, Size: 49, Number: 7642119
< 2015-12-07 08:21:01.007 Type: SSH_FXP_STATUS, Size: 29, Number: 7642119
< 2015-12-07 08:21:01.007 Status code: 2
. 2015-12-07 08:21:01.007 Opening remote file.
> 2015-12-07 08:21:01.007 Type: SSH_FXP_OPEN, Size: 65, Number: 7642371
< 2015-12-07 08:21:01.038 Type: SSH_FXP_HANDLE, Size: 13, Number: 7642371
> 2015-12-07 08:21:01.038 Type: SSH_FXP_WRITE, Size: 32764, Number: 7642886
. 2015-12-07 08:21:04.096 1112 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:21:04.096 Type: SSH_FXP_CLOSE, Size: 13, Number: 7786500
< 2015-12-07 08:21:04.112 Type: SSH_FXP_STATUS, Size: 24, Number: 7784198
< 2015-12-07 08:21:04.127 Type: SSH_FXP_STATUS, Size: 24, Number: 7784454
< 2015-12-07 08:21:04.127 Type: SSH_FXP_STATUS, Size: 24, Number: 7784710
< 2015-12-07 08:21:04.127 Type: SSH_FXP_STATUS, Size: 24, Number: 7784966
< 2015-12-07 08:21:04.127 Type: SSH_FXP_STATUS, Size: 24, Number: 7785222
< 2015-12-07 08:21:04.143 Type: SSH_FXP_STATUS, Size: 24, Number: 7785478
< 2015-12-07 08:21:04.143 Type: SSH_FXP_STATUS, Size: 24, Number: 7785734
< 2015-12-07 08:21:04.143 Type: SSH_FXP_STATUS, Size: 24, Number: 7785990
< 2015-12-07 08:21:04.158 Type: SSH_FXP_STATUS, Size: 24, Number: 7786246
< 2015-12-07 08:21:04.580 Type: SSH_FXP_STATUS, Size: 24, Number: 7786500
< 2015-12-07 08:21:04.580 Status code: 0
> 2015-12-07 08:21:04.580 Type: SSH_FXP_REMOVE, Size: 40, Number: 7786765
< 2015-12-07 08:21:04.626 Type: SSH_FXP_STATUS, Size: 24, Number: 7786765
< 2015-12-07 08:21:04.626 Status code: 0
> 2015-12-07 08:21:04.626 Type: SSH_FXP_RENAME, Size: 84, Number: 7787026
< 2015-12-07 08:21:04.673 Type: SSH_FXP_STATUS, Size: 24, Number: 7787026
< 2015-12-07 08:21:04.673 Status code: 0
. 2015-12-07 08:21:04.673 Preserving timestamp [2015-12-07T11:33:52.000Z]
> 2015-12-07 08:21:04.673 Type: SSH_FXP_SETSTAT, Size: 56, Number: 7642633
< 2015-12-07 08:21:04.704 Type: SSH_FXP_STATUS, Size: 24, Number: 7642633
< 2015-12-07 08:21:04.704 Status code: 0
. 2015-12-07 08:21:04.704 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Prospect Status_3.4.CSV' [18343887]
. 2015-12-07 08:21:04.704 File: 'C:\Users\RE_Queue\Downloads\Queue output\Relationship Type_1.4.CSV' [2015-12-07T11:46:31.932Z] [15675223]
. 2015-12-07 08:21:04.704 Copying "C:\Users\RE_Queue\Downloads\Queue output\Relationship Type_1.4.CSV" to remote directory started.
. 2015-12-07 08:21:04.704 Binary transfer mode selected.
. 2015-12-07 08:21:04.704 Checking existence of file.
> 2015-12-07 08:21:04.704 Type: SSH_FXP_LSTAT, Size: 42, Number: 7787271
< 2015-12-07 08:21:04.751 Type: SSH_FXP_ATTRS, Size: 37, Number: 7787271
. 2015-12-07 08:21:04.751 Checking existence of partially transfered file.
> 2015-12-07 08:21:04.751 Type: SSH_FXP_LSTAT, Size: 51, Number: 7787527
< 2015-12-07 08:21:04.798 Type: SSH_FXP_STATUS, Size: 29, Number: 7787527
< 2015-12-07 08:21:04.798 Status code: 2
. 2015-12-07 08:21:04.798 Opening remote file.
> 2015-12-07 08:21:04.798 Type: SSH_FXP_OPEN, Size: 67, Number: 7787779
< 2015-12-07 08:21:04.829 Type: SSH_FXP_HANDLE, Size: 13, Number: 7787779
> 2015-12-07 08:21:04.829 Type: SSH_FXP_WRITE, Size: 32764, Number: 7788294
. 2015-12-07 08:21:07.450 948 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2015-12-07 08:21:07.450 Type: SSH_FXP_CLOSE, Size: 13, Number: 7910916
< 2015-12-07 08:21:07.450 Type: SSH_FXP_STATUS, Size: 24, Number: 7908614
< 2015-12-07 08:21:07.450 Type: SSH_FXP_STATUS, Size: 24, Number: 7908870
< 2015-12-07 08:21:07.466 Type: SSH_FXP_STATUS, Size: 24, Number: 7909126
< 2015-12-07 08:21:07.466 Type: SSH_FXP_STATUS, Size: 24, Number: 7909382
< 2015-12-07 08:21:07.482 Type: SSH_FXP_STATUS, Size: 24, Number: 7909638
< 2015-12-07 08:21:07.482 Type: SSH_FXP_STATUS, Size: 24, Number: 7909894
< 2015-12-07 08:21:07.482 Type: SSH_FXP_STATUS, Size: 24, Number: 7910150
< 2015-12-07 08:21:07.482 Type: SSH_FXP_STATUS, Size: 24, Number: 7910406
< 2015-12-07 08:21:07.482 Type: SSH_FXP_STATUS, Size: 24, Number: 7910662
< 2015-12-07 08:21:07.762 Type: SSH_FXP_STATUS, Size: 24, Number: 7910916
< 2015-12-07 08:21:07.762 Status code: 0
> 2015-12-07 08:21:07.762 Type: SSH_FXP_REMOVE, Size: 42, Number: 7911181
< 2015-12-07 08:21:07.809 Type: SSH_FXP_STATUS, Size: 24, Number: 7911181
< 2015-12-07 08:21:07.809 Status code: 0
> 2015-12-07 08:21:07.809 Type: SSH_FXP_RENAME, Size: 88, Number: 7911442
< 2015-12-07 08:21:07.856 Type: SSH_FXP_STATUS, Size: 24, Number: 7911442
< 2015-12-07 08:21:07.856 Status code: 0
. 2015-12-07 08:21:07.856 Preserving timestamp [2015-12-07T11:46:31.000Z]
> 2015-12-07 08:21:07.856 Type: SSH_FXP_SETSTAT, Size: 58, Number: 7788041
< 2015-12-07 08:21:07.887 Type: SSH_FXP_STATUS, Size: 24, Number: 7788041
< 2015-12-07 08:21:07.887 Status code: 0
. 2015-12-07 08:21:07.887 Transfer done: 'C:\Users\RE_Queue\Downloads\Queue output\Relationship Type_1.4.CSV' [15675223]
. 2015-12-07 08:21:07.887 File: 'C:\Users\RE_Queue\Downloads\Queue output\Staff Information_3.2.CSV' [2015-12-07T11:46:32.836Z] [5528]
. 2015-12-07 08:21:07.887 Copying "C:\Users\RE_Queue\Downloads\Queue output\Staff Information_3.2.CSV" to remote directory started.
. 2015-12-07 08:21:07.903 Binary transfer mode selected.
. 2015-12-07 08:21:07.903 Opening remote file.
> 2015-12-07 08:21:07.903 Type: SSH_FXP_OPEN, Size: 58, Number: 7911683
< 2015-12-07 08:21:07.934 Type: SSH_FXP_HANDLE, Size: 13, Number: 7911683
> 2015-12-07 08:21:07.934 Type: SSH_FXP_WRITE, Size: 5553, Number: 7912198
> 2015-12-07 08:21:07.934 Type: SSH_FXP_CLOSE, Size: 13, Number: 7912452
> 2015-12-07 08:21:07.934 Type: SSH_FXP_SETSTAT, Size: 54, Number: 7911945
< 2015-12-07 08:21:07.981 Type: SSH_FXP_STATUS, Size: 24, Number: 7912198
< 2015-12-07 08:21:08.028 Type: SSH_FXP_STATUS, Size: 24, Number: 7912452
< 2015-12-07 08:21:08.028 Status code: 0
. 2015-12-07 08:21:08.028 Preserving timestamp [2015-12-07T11:46:32.000Z]
Re: Task Scheduler not working- Error: No such file - Script: Failed
For the transfer from from Scheduler, there was a partially uploaded file existing already. Can you remove it and try again (and post a new complete log)? Can you post a complete log for the GUI too (without removing the log header)?
Please attach the logs, instead of pasting them to message text.
tmorris431
Logs not attached. While I was waiting for your response I compared all the settings on Task Scheduler, WinSCP and the script and command files between the old set up and the new. It turns out when they set this up they forgot to stop the process on the original machine which was no longer being updated. So every day it would upload old files over the new files. Everything is working beautifully now, finally. Thanks for your time! :D
