Unable to connect to server using winscp from windows 7 machine / laptop
sourabh chavan
Newyork
Could any one please help me out with connecting to server using windows 7 machine / laptop.
I am able to connect to server using putty with same credentials but it doesn't work for winscp.
When i enter the credentials it will say connecting but it exit out without any error message.
Regards,
Sourabh
Re: Unable to connect to server using winscp from windows 7 machine / laptop
sourabh chavan
Newyork
I have attached the log file as you have requested. Version of Winscp which I am using is 5.7.6
Well, the server is closing the session. Maybe it does not support SFTP. Can you connect with any other SFTP client?
