Need to delete the files on the server after we pull them.
HI we are getting files from ecom site that has our customers orders. This is now working well. But in SCP manual process we then delete the files in that server, having permissions of course. The question is how to do this in the .net program.
// Setup session options
Protocol = Protocol.Sftp,
HostName = ConfigurationManager.AppSettings["HostName"].ToString(),
UserName = ConfigurationManager.AppSettings["UserName"].ToString(),
Password = ConfigurationManager.AppSettings["Password"].ToString(),
SshHostKeyFingerprint = ConfigurationManager.AppSettings["SshHostKeyFingerprint"].ToString()
// Connect
session.Open(sessionOptions);
RemoteDirectoryInfo directory = session.ListDirectory(ConfigurationManager.AppSettings["RemotePath"].ToString());
foreach (RemoteFileInfo fileInfo in directory.Files)
Console.WriteLine("{0} with size {1}, permissions {2} and last modification at {3}",
fileInfo.Name, fileInfo.Length, fileInfo.FilePermissions, fileInfo.LastWriteTime);
string fileName = fileInfo.Name;
string remotePath = ConfigurationManager.AppSettings["RemotePath"].ToString() + fileName;
// string localPath = "d:\\backup\\" + fileName;
string localPath = ConfigurationManager.AppSettings["LocalPath"].ToString() + fileName;
if (session.FileExists(remotePath))
bool download;
if (!File.Exists(localPath))
Console.WriteLine("File {0} exists, local backup {1} does not", remotePath, localPath);
download = true;
else
DateTime remoteWriteTime = session.GetFileInfo(remotePath).LastWriteTime;
DateTime localWriteTime = File.GetLastWriteTime(localPath);
download = true;
if (download)
// Download the file and throw on any error
session.GetFiles(remotePath, localPath).Check();
Console.WriteLine("Download to backup done.");
else
Console.WriteLine("File {0} does not exist yet", remotePath);
return 0;
catch (Exception e)
Console.WriteLine("Error: {0}", e);
return 1;
// Connect
bool download;
download = true;
else
download = true;
if (download)
else
return 0;
catch (Exception e)
return 1;
