All steps OK but not getting the files in .NET
Pimhach
New Jersey
I have a task to do SFTP in a .NET program. Everything is fine except that we are not getting back the files. In Debugging am not getting any errors in the steps but problem is no files coming back. in the manual SCP, we have to copy paste the files that come back, we wanted to automate this.
App.config
<appSettings>
    <add key="HostName" value="Groups.sftp.myhub.com" />
    <add key="UserName" value="Groups" />
    <add key="Password" value="mypassword" />
    <add key="SshHostKeyFingerprint" value="ssh-rsa 2047 za:5z:z6:77:36:d6:94:89:44:15:b0:ca:59:bf:d3:92" />
    <add key="LocalPath" value="\\server-app01\cust\SC\AMAZON\WINSCP\TESTAMAZON" />
    <!-- this is local folder path -->
    <add key="RemotePath" value="/outgoing/orders/AMAZON/" />
    <!--   this is remote system directory path -->
    <add key="ClientSettingsProvider.ServiceUri" value="" />
  </appSettings>
Program.cs
// Setup session options SessionOptions
sessionOptions = new SessionOptions {
    //Passing HostName , Password, & UserName here. port number
    Protocol = Protocol.Sftp,
    HostName = ConfigurationManager.AppSettings["HostName"].ToString(),
    UserName = ConfigurationManager.AppSettings["UserName"].ToString(),
    Password = ConfigurationManager.AppSettings["Password"].ToString(),
    SshHostKeyFingerprint = ConfigurationManager.AppSettings["SshHostKeyFingerprint"].ToString()
string LocalPath = ConfigurationManager.AppSettings["LocalPath"].ToString();
string RemotePath = ConfigurationManager.AppSettings["RemotePath"].ToString();
    // Connect
    session.Open(sessionOptions);
    // Upload files
    transferOptions.TransferMode = TransferMode.Binary;
    TransferOperationResult transferResult;
    transferResult = session.PutFiles(LocalPath + "*", RemotePath, false, transferOptions);
    // Throw on any error
    transferResult.Check();
Re: All steps OK but not getting the files in .net
You probably want to add a backslash between the localPath and the *.
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
