Filemask on synchronize local fails
FrankR13
I keep getting this error:
> 2015-11-23 11:59:26.633 Script: synchronize -filemask="|*org.pdf" local
. 2015-11-23 11:59:26.633 Script: Failed
My goal is to exclude al files ending on org.pdf. If I ommit the -filemask option everything works but I get the undesired org.pdf files. It doesn't matter what filemask I use, it always gives an error.
My WinSCP version is 5.7.6 (Build 5874).
Re: Filemask on synchronize local fails
FrankR13
Thank you very much for your reply. I solved the problem. The solution is pretty stupid :-(
I already upgraded the WinSCP installation on the server. So I knew what the version should be. When I created a complete logfile and was checking for text I wanted to hide, I noticed an much older version number 4.2.9. Strange, becaause I checked the version in de WinSCP GUI.
It turns out that someone had the great idea to put the winscp.exe with te location of the scripts that call the executable. That way it is easier to copy to other servers. The downside is that an upgrade of WinSCP won't upgfrade that file......
After copying the WinSCP file to the second location the filemask worked and the log also looked different.
