WinSCP script command unzip files automatically
stargazer99tang
I just downloaded your latest WinSCP version on this website. I'm trying to perform batch files download over SFTP with it. I notice that the zip files I download will get unzip automatically. May I know why this is so and how I can prevent this from happening?
Here's a snippet of the script I use:
option batch on
option transfer binary
open user:password@server
get source destination
close
All source files are in .zip format. There are no failures in transfer except that I don't need WinSCP.com to unzip my files automatically.
Re: WinSCP script command unzip files automatically
WinSCP does not extract any archives. It must be your server that is doing this.
stargazer99tang
I'm using WinSCP 5.7.6 (Build 5874). I'm attaching the download script and logs as private attachment for your perusal.
Screenshot of the download result attached as well.
  • private.zip (28.73 KB, Private file)
Description: Screenshot of files downloaded, WinSCP script and log files
I need a session log file (/log=session.log), not XML log.
