Stuck on Syncronizing...
kleach
I am trying to sync a local directory structure and files with a remote one..
I ran a remote sync command and it walked through comparing all the directories and then looked like it would start syncing.. but hangs... one note.. in the first dir there are over 10k image files.
C:\Program Files (x86)\WinSCP>WinSCP.com /log="C:\Users\SQLAdmin\Documents\winscp.log" /loglevel=2
winscp> open <<<ftp site>>>
Connecting to <<<ftp site>>> ...
Connected
Starting the session...
Session started.
Active session: [1] <<<ftp site>>>
winscp> synchronize remote "D:\Images\Files" "/"
Comparing...
Local 'D:\Images\Files\z' => Remote '/z'
Synchronizing...
The tail of the log shows..
. 2015-11-18 14:08:20.238 Local file 'D:\Images\Files\z\ZT-Z34-3G-DFLY-RMR-DLC_1.jpg' [2015-10-19T19:53:41.000Z] [10374] is new
. 2015-11-18 14:08:20.238 Local file 'D:\Images\Files\z\ZT-Z34-3G-DFLY-RMR-FDE_1.jpg' [2015-11-17T20:51:44.000Z] [11536] is new
< 2015-11-18 14:08:20.769 Script: Synchronizing...
. 2015-11-18 14:08:20.769 Synchronizing local directory 'D:\Images\Files\' with remote directory '/', params = 0x2 (NoConfirmation)
. 2015-11-18 14:08:20.769 Synchronizing local directory 'D:\Images\Files\#\' with remote directory '/#/', params = 0x2 (NoConfirmation)
it has been there for hours..
no progress...
I have connected to the site via Filezilla with the same credentials and manually moved a file to the folder to be sure it was not a permissions issue.
I have the latest version (downloaded today 11/18/2015)
Any ideas?
kleach
It did start moving... took 4 hours to begin? Not sure what could be causing the issue? Maybe another FTP process was hanging it? like filezilla? how is that possible?
Re: Stuck on Syncronizing...
