Error parsing session log file
lakshmi
We followed the below link while winscp.net implementation by using version 5.7.6(Build 5874).
https://winscp.net/eng/docs/library#csharp
As part of file upload, SessionLogPath is mandatory before open session.
So we start with the following code after Setuping the session options
session.SessionLogPath = @"D:\winScpLog\";
session.Open(sessionOptions);
While executing we got the following error.
Error parsing session log file:
{WinSCP.SessionLocalException: Error parsing session log file ---> System.Xml.XmlException: '', hexadecimal value 0x07, is an invalid character. Line 2, position 62.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowInvalidChar(Char[] data, Int32 length, Int32 invCharPos)
at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at WinSCP.SessionLogReader.DoRead()
--- End of inner exception stack trace ---
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.Open(SessionOptions sessionOptions)
at WinSCPFileUpload.Form1.BtnUpload_Click(Object sender, EventArgs e)
Please guide us to solve the issue related to file upload task.
Re: Error parsing session log file
Please attach a full debug log file (Session.DebugLogPath) showing the problem.
You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names. If you do not want to post the log publicly, you can mark the attachment as private or email it to me.
lakshmi
Thanks for your support.
As par your suggestion,I set the Session.DebugLogPath and checked the application with fallowing code lines.
WinSCP.SessionOptions sessionOptions = new SessionOptions
Protocol = Protocol.Sftp,
HostName = "xxx.xxx.xx.xxx",
UserName = "xxxxxx",
Password = "xxxxxx",
SshHostKeyFingerprint = "ssh-rsa 1536 xx:xx:xx:xxx"
session.SessionLogPath = Server.MapPath("~/Log/logSftp.log");////"your log path";
session.DebugLogPath = Server.MapPath("~/Log/logSftp.log");
session.ExecutablePath = Server.MapPath("~/bin/winscp.exe");
session.DisableVersionCheck = true;
// Connect
// Upload files
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult;
transferResult = session.PutFiles(@"d:\toupload\*", "/home/user/", false, transferOptions);
// Throw on any error
transferResult.Check();
Even-though I got the same error while calling the statement session.Open(sessionOptions).Kindly provide guide lines how to configure the session related logging information.
[quote="prikryl"]Please attach a full debug log file ([m]Session.DebugLogPath[/m]) showing the problem.
[size=12]You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names. If you do not want to post the log publicly, you can mark the attachment as private or email it to me.[/size][/quote]
The SessionLogPath and the DebugLogPath must be different.
And mainly, this was not supposed to fix the problem. This was to generate the debug log file, so that you can attach it here for us to investigate.
lakshmi
I am sending the sample application for your reference.I am unable to store the debug logs.Please provide further steps to upload files.
  • WinSCPExample.zip (4.56 MB, Private file)
Description: Sample application
We cannot debug your application.
Why are you unable to store the debug logs?
sushma
India
Did you get any solution for this?
must we should give the Session log path and Debug log path?
guest123
Exception: WinSCP.SessionLocalException: Error parsing session log file
Hi all, I am using WinSCP .net assembly in visual studio obtained via NuGet package manager command: Install-Package WinSCP -Version 5.13.7.0
I am getting the following error when I do in code:
Any advice on work around would be appreciated:
[2019-02-24 12:22:37.310Z] [0001] Exception: WinSCP.SessionLocalException: Error parsing session log file ---> System.Xml.XmlException: Unexpected XML declaration. The XML declaration must be the first node in the document, and no white space characters are allowed to appear before it. Line 3, position 3.
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ParsePI(StringBuilder piInDtdStringBuilder)
at System.Xml.XmlTextReaderImpl.ParseElementContent()
[2019-02-24 12:22:37.310Z] [0001] at WinSCP.Logger.WriteException(Exception e)
at WinSCP.ElementLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.ElementLogReader.ReadToEnd(LogReadFlags flags)
at WinSCP.ElementLogReader.Dispose()
at WinSCP.SessionElementLogReader.Dispose()
at WinSCP.Session.Cleanup()
at TestSftpApp.Program.Download1()
at TestSftpApp.Program.Main(String[] args)
Re: Exception: WinSCP.SessionLocalException: Error parsing session log file
Please start a new topic for your problem and include a complete session and debug log files.
