Get & Put save only if the transfer is completed.
Dimitris
Hello, i need your help!!! :D :D
That's my senario:
I have an FTP server(in IIS @server21012R2 ) in branchA
I have winscp client in Branch B
I run the following script at Branch B every hour:
option batch abort
# Connect to FTP server using a password
open ftp://username:password@192.168.1.1:21
# download file delete after completion exclude subfolders
cd /Outbox/
Option exclude */
get -delete *.* F:\Sync\Inbox\*.*
# Disconnect
close
With this senario if i lost the connection while the files transfering. I receive one file for example "test.txt" which is not completed.
Because it is not completed it will not be deleted from the server and when it comes the time to repeat the script it i will be received completely.
The problem is that i don't want to save the file if it is not completed download because i use that files for another operation and until running again the script i have already used these files and i received errors to the application.
Is there any way to solve it? Thanks in advance. If you want any details i can upload
Additionally i do the same for the uploading:
option batch abort
# Upload file After complete delete files from source
cd /Inbox
Option exclude */
put -delete F:\Sync\Outbox\*.*
# Disconnect
close
Re: Get & Put save only if the transfer is completed.
There's no easy solution with FTP protocol.
With SFTP, WinSCP appends a .filepart extension to incomplete files. But not with FTP.
