powershell 5.0.10240.16384 error - unable to find type [WinSCP.Protocol]
lukegracie
I'm just starting with WinSCP and Powershell. I've been using WinSCP in SSIS with much success - Thank you Martin! I can't seem to get started with Powershell. I'm on Windows 10 and Powershell 5 using the Windows Powershell ISE as an Administrator. I'm stuck using WinSCP 5.5.6 right now.
My test errors out right at the beginning.
    # Load WinSCP .NET assembly
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protcol]::Sftp
Error: Unable to find type [WinSCP.Protcol].
Thanks for your help and pointing me in the right direction.
Luke
