2-finger scroll in right hand explorer view not working
HHoitz
hello,
i think i found a minor bug in this great piece of software.
I am using winscp 5.7.6 build 5874 under windows 10 build 10565 on a dell xps13 (2015), which has a precision touchpad. When trying to scroll the righthand window in explorer (details view) with the 2-finger scroll on the touchpad, the scroll bar is moving correctly, but the contents of the window does not move. When i lift fingers from touchpad, the scrollbar is jumping back to it's original position.
Moving the scroll bar directly works fine.
Doing the same 2-finger-scroll in the left hand window (treeview), everything works as expected.
Re: 2-finger scroll in right hand explorer view not working
I was not able to reproduce the problem on neither Lenovo nor Asus (both Windows 10).
eleigh
Cambridge, UK
Confirmation of scroll bug
I am experiencing the same scroll bug, with the same or similar model of Dell XPS13 laptop (P54G) with Windows 10 x64 and the same build of WinSCP. The two-finger scroll works in the tree view panes, but not in the tabulated list view windows. This is probably a bug in the underlying library for the list view pane.
Re: Confirmation of scroll bug
Ovidiu
2-finger scroll in Commander
I am experiencing the same behavior as 'HHoitz' mentioned in original post, however this is on 'Commander' interface (when using touchpad two-fingers scrolling the bar moves but content doesn't, upon release bar moves to initial location)
- winscp 5.7.7 (Build 6257)
- there is no previous version when this worked - far as I know
- Options->Preferences->Interface->Commander
- windows 10 home/64 - on an Acer laptop
This might not be a bug but rather a new feature, but still this would be nice to have.
Re: 2-finger scroll in Commander
Ovidiu
Email sent.
bobbel
I'm facing the same problem with a new Dell XPS 15 (9550).
Configuration is Commander view in WinScp 5.7.7 (Build 6257) on Win 10 Pro 64bit.
pikalaxalt
Philadelphia, PA
I have also experienced this problem on a Microsoft Surface Pro 3 running Windows 8, Windows 8.1, Windows 10, and now Windows 10 Anniversary Edition, using either the trackpad on the Type Cover 3, Type Cover 4, or the scroll wheel on a Microsoft Bluetooth comfort mouse. Just installed version 5.9.1, problem persists. Problem also persists on a brand new desktop computer with both a Logitech M340 mouse and the same Bluetooth mouse previously mentioned.
The scroll bar on the right hand side moves in response to an up or down scrolling gesture, but the file list does not follow; upon release of the scrolling gesture, the scroll bar snaps back to match the file list.
Thanks for the details. Can you try to attach the "Microsoft Bluetooth comfort mouse" to few other machines, to check, if you get the same problem?
nathaniel515
Minnesota, USA
I have this issue as well with Dell XPS 15 9550, Windows 10 Build 14393. It seems that WinSCP fails to work properly with the Microsoft Precision Touchpad driver. WinSCP 5.9.2 build 6958.
Ovidiu
Solved
This has been fixed on v 5.9.6 for me.
I can scroll with 2 fingers from my acer touchpad.
Greatly appreciated and many thanks to Martin!
Re: Solved
As we later discussed over an email, it was rather a fix/update of a Synaptics device driver (which came with Windows 10 Creators Update), that resolved the problem, rather than WinSCP upgrade.
bobbel wrote:
I can confirm, that it's now working on Win10 Pro 64bit on a Dell XPS 15 9550. Great! :D
Thanks for your feedback!
