How can i start command line mode
clarion
hello,
i'm using winscp3 on windows xp und want to run a script. how can i start command line mode?
i tried winscp3.com, but windows can't find any file winscp3.com
thanks
clarion
Re: How can i start command line mode
To get winscp3.com you need to install WinSCP, you are proably using standalone version. Or use /console option for winscp3.exe.
technonaut
winscp.com missing ?
You mentioned that with winscp3, you can run winscp3.exe /console instead of winscp.com. Does that mean that winscp.com was discontinued in version 3? The tutorials and such on the website all mention winscp.com - they should probably be updated if this is the case.
