Synchronised browing un-syncing if changing 2 or more directories too quickly
Ysu
Australia
The synchronised browsing (great feature, btw!) can get out of sync, if you change the local directories too quickly. Then the feature is still switched on, but the directories are different. If you try a further directory change, the program will potentially ask you to create a new directory. The only way out of it is to disable the synchronised browsing, navigate the directories to match, then switch it back on.
Best solution would be if the program could "remember" too quick changes and follow them at its own pace.
Less-good solution would be a warning pop-up and switching the feature off.
Thanks!
Using version 5.7.5 (Build 5665)
Re: Synchronised browing un-syncing if changing 2 or more directories too quickly
How are you changing the directory? Keyboard? Mouse (where? file panel, directory tree)
Ysu
Australia
I'm using keyboard, in file panel view, and it really only happens if/when the network is rather busy, and usually a change of up/down in another branch.
If I install the debug version again, it maybe some time before I get it happen again - is that all right? Or is there anything (emptying cache or logs) that's needed regularly?
That's OK. Thanks.
