Moving file with a specific modified date
mbaybarsk
Hi Folks,
I'm completely new to WinSCP scripting and I need to come up with a filemask that needs to select files that were created/modified exactly between 11:00 AM and 11:01 AM.
I wonder if this would work:
mv *.*>=11:00<=11:01
OR do I need to have a date before the time?
If yes, can I use %TIMESTAMP% such as:
mv *.*>=%TIMESTAMP#yyyy-mm-dd% 11:00<=%TIMESTAMP#yyyy-mm-dd% 11:01
Thanks,
B
Re: Moving file with a specific modified date
This is correct. Just you need to close the mask to double-quotes as it contains spaces:
mv "*.*>=%TIMESTAMP#yyyy-mm-dd% 11:00<=%TIMESTAMP#yyyy-mm-dd% 11:01"
