Can I run both Filezilla and Win-SCP on the same computer?
redsue12
I find that both have their purposes...but they seem to be incompatible on the same computer. Is this a known issue?
Re: Can I run both Filezilla and Win-SCP on the same computer?
There should be no problem.
What problem are you facing specifically?
What does FileZilla do that WinSCP cannot?
