Connection has been unexpectedly closed. Server sent command exit status 0.
drew.tittle
I'm using winscpnet.dll to connect to BitViseSSH Server in a powershell script
In the script I'm attempting to use a .xml file to make a config file of sorts. I was getting the above error and looked through the suggestions on this link, none of which were helpful in my situation.
https://winscp.net/eng/docs/message_exit_status_1
As it turns out the issue I was having is I'm using an SSH key for authentication and this error was basically saying it couldn't find the private key I was using for authentication. The login succeeded but the Key authentication failed because it couldn't find the key in the path I specified.
Just thought I'd put this somewhere so other people with the same error can find it as a possible solution
