Using programs remotely via WinSCP
bravozullu
I am new to WinSCP. I am using it to connect to my network at school. I can do this; I see all of my files, directories, and everybody else's files/directories.
Now, when I try to launch a program in the terminal window [for instance, I try to run MATLAB, by typing in 'matlab', the executable command], the program does not run. [Normally at school, the MATLAB GUI pops up, and I'm ready to go.]
How do I make this GUI (as well as the GUI's of other programs] pop up through WinSCP on my home computer? Do I need some sort of plug in? What am I missing here?
Please advise,
Arnie
michaa
Re: Using programs remotely via WinSCP
Hm, me be I do not understand what you try to do, but as nobody esle is answering, I do my best:
WinSCP is a file manager for secure file transmissions. It is not VNC.
The terminal you are using via WinSCP is a shell, not a desktop. There is no "window".
Your progamm MATLAB GUI, is it a shell application or a desktop application? Does it need root permission? Is login allowed for root?
If MATLAB GUI is a shell application (like mc), you should try putty first. If it is a desktop application, you cant use it via putty/WinSCP.
_________________
greetz
michaa
Michaa is right.
You maybe theoretically possible to run GUI application from console. But you need to have running another application on your desktop, so called X-windows server.
