RTL/Arabic Trans. Bugs
style
Thank you for making this great program.
I just want to tell Suhaila and the rest of developing teams about the interface bugs when changing to Arabic language and mirroring (rtl) things. Some components, such as port number fields in the login window, and some labels, such the word File in upload window, are broken. It would be also great if you get trees and progress bars to be mirrored as well.
I can post screenshots if things are not clear.
Good luck.
Re: RTL/Arabic Trans. Bugs
I'm aware of the fact that the support for RTL languages is far from perfect. Some of the problems you describer will be fixed, some not.
