WinSCP fails to connect my OpenSSH_3.5p 1(on w2k server w/ sp3)
Hi, I'm a newbie.
I kept receiving "Error skipping startup message" everytime try to connect. I followed the instruction on OpenSSH website to change the remote directory (/) and Shell to \ssh\sh, but is still fails. Please help. Million thanks.
LL
. WinSCP Version 2.2.0 (Build 122)
. Login time: Friday, February 28, 2003 6:31:19 PM
. Session name: ftpguest1@ftpserver
. Host name: spbosftp (Port: 22)
. User name: ftpguest1 (Password: Yes, Key file: No)
. SSH protocol version: 2; Compression: Yes
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 0 sec (0 = off); Timeout: 15 sec
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Return code variable: Autodetect; Lookup user groups: No
. Shell: /ssh/sh , EOL: 1
. Local directory: default, Remote directory: /, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "ftpserver"
. Connecting to 10.1.1.1 port 22
. Server version: SSH-2.0-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Jan 26 2003 11:53:20
. Host key fingerprint is:
. ssh-rsa 1024 58:7f:46:45:58:ab:ac:65:7d:8c:cc:b7:45:a0:8a:9d
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
. Keyboard-interactive authentication refused
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Doing startup conversation with host (shell).
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
! setgid: Invalid argument
. Server sent command exit status 1
* (ESshFatal) Error skipping startup message.
Re: WinSCP fails to connect my OpenSSH_3.5p 1(on w2k server w/ sp3)
You have wrong configured permissions. I remember that I had same problem. There is some file such as 'readme'??? in the instalation package, which explains what to do.
Michael
In order to solve the problem with setgid, you need to make sure that you have added all of your domain groups and local groups to the etc/group file in your Win2K OpenSSH installation.
mkgroup -l >> ..\etc\group     # (local groups)
mkgroup -d >> ..\etc\group     # (domain groups)
You need to edit the file afterwards and remove and duplicate entries.
rediguana
Firstly thanks for the great piece of software!
I got the same error as the original poster. However I checked my groups, and there are only unique groups there. I only imported local groups as I am on a workgroup, not a domain. Also, my username gid in passwd matched up with a group gid.
I tried logging in with some other SSH/SFTP capable packages to the Win2k sshd and they worked fine. It appears that the server is working fine. The two sample packages were Putty and ssh on RedHat 8.0.
The error that WinSCP2 comes up with is 'Error skipping startup message' and in a smaller box 'Can't detect command return code'. Have you any more suggestions? How can I provide more information for you?
The server was OpenSSH 3.5p1-3 on W2k.
Cheers Gav
Sorry about that, found the appropriate forum posts. Works a charm! :D
Cheers Gav
Tonny Roger Holm
:-( I have the same problem. What was the solution?
/Tonny
Peter
I have almost the same Problem. Habe a Linux Server wit 3.6.1p1 Openssh installed and openssl 0.9 installed. I can connect with SSH1 but not with SSH2 . Tried another program SSH2Pro as a client, and this worked. But I prefer your SW as it is great (FTP like and Freeware)
Below is my log file for WinSCP 2.20 ..(by the way I am using the WinSCP with my Linux and SSH1. Working Perfect. Thanks for your great Freeware .)
Looking up host "10.1.1.66"
. Connecting to 10.1.1.66 port 22
. Server version: SSH-1.99-OpenSSH_3.6.1p1
. ssh-rsa 1024 35:5d:60:f9:3b:cb:29:67:8b:23:8b:58:1a:f6:be:27
. Reading private key file "C:\WINDOWS\Profiles\music\Desktop\t\privatejob.PPK"
. Offered public key
! Server refused our key
. Server refused public key
! No supported authentication methods left to try!
. No supported authentications offered. Disconnecting
* (ESshFatal) Not connected!
AND HERE SSH1 WORKING:
. Login time: Dienstag, 8. April 2003 08:38:42
. Session name: jobpilot@10.1.1.66
. Host name: 10.1.1.66 (Port: 22)
. User name: jobpilot (Password: No, Key file: Yes)
. SSH protocol version: 1; Compression: No
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No
. Looking up host "10.1.1.66"
. We claim version: SSH-1.5-PuTTY-Local: Jan 26 2003 11:53:20
. Using SSH protocol version 1
. Received public keys
.       1024 c8:e6:ca:99:81:6d:0e:f4:a4:e2:81:c7:91:63:5d:cf
. Encrypted session key
. AES not supported in SSH1, skipping
. Using Blowfish encryption
. Trying to enable encryption...
. Initialised Blowfish encryption
. Installing CRC compensation attack detector
. Successfully started encryption
. Sent username "jobpilot"
. Trying public key "C:\WINDOWS\Profiles\music\Desktop\t\ssh1jobP.PPK"
! Wrong passphrase.
. Remote dRSA authentication accepted.
. Authentication successful
. Started session
cut cut and here it continues....
Eldon Ziegler
:?: I too have this problem with both client and server on W2K Pro. What was the solution? I've tried all combinations of mkpasswd and mkgroup.
@Peter: Are you sure that privatejob.PPK key is registered as authorized SSH2 key on your server?
