help uploading unicode html files
guest_philipp
my problem i want to transfer files as unicode. but the editor won't let me paste unicode snippets (showing lots of ???s only). i tried using windows editor too but it won't let me upload unicode as well. i also tried playing around with the transfer mode settings but couldnt find a unicode option. i found no help in the faq either. please help!
thanks in advance.
Philipp
Re: help uploading unicode html files
The internal editor of WinSCP probably does not support unicode. You have to use external editor.
guest_philipp
ok thanks mate. ill keep trying. i found another workaround in the meantime. i'm using
<invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>)
now to convert my text. maybe you should raise unicode compatibility for the editor as an issue for future versions?
regards
Philipp
