Missing "type" column in remote panel
Missing Type column in remote panel
  1. Right click in remote panel
  2. Choose "Show Columns"
Expected: Type should be in the submenu as it is for the local panel
Problem: Type is missing from submenu.
Re: Norton commander style view
Type column is absent by purpose. IMHO this has no meaning for remote files. But as several people demand this for some reason, I consider adding it. BTW, why do you need it?
Tim
I've been looking for this too
I've been looking for a remote file Type column as well. It would come in very handy sometimes. For instance, if I compile Java code on my local Windows machine and upload to a Linux server, I want to upload only .class files, not .java files. This is easily done, because I can order by file Type locally. But if I upload a few directories at once, I might want to delete the remote .java source files because they never get updated when I upload only .class files. If I could sort the remote files by Type, I could easily delete the files I don't want, or easily download only the files I want. Thanks.
Re: I've been looking for this too
  1. You can sort files by extension
  2. You can select files by extension
  3. You can skip files by extension from upload/download
zlbb
Revive from the dead :)))
I use version 6.3.6 and remember I had "Type" column just after installing WinSCP. But some time passed and it's gone. I didn't change any settings.
I also the one who needs type-sorting feature because sometimes I just need to make a quick glance to find only files of certain types on remote panel.
Reply with quote E-mail
zlbb
@martin, got it. Thank you.
But still have some strange behavior.
Type column is enabled but not shown.
But when I just reinstalled WinSCP, Type was visible. I couldn't notice when exactly it disappeared.
@zlbb: If you can work with Windows registry, please backup and try to delete this value:
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\RemotePanel]
"DirViewParams"=...
Please send me the original value.
