Delete from left pane (tree)
emmanuel
Hello all,
Would it be possible to extend WinSCP to contain same actions in the left pane right-click pop-up menu (i.e., Delete), as those that exist in the right pane?
Kind regards
Emmanuel
Re: Delete from left pane (tree)
Left (local) pane have system popup menu. IFAIK it contains delete command on all platforms, doesn't it?
