While connecting to a the Fedora Linux system, I get this error Network Error "No route to host"
SSH is working on the Linux Box and when I ping from the windows machine it does work.
Could someone help me with the error debugging
martin ◆
So do I understand right that you can connect with other SSH client? Have you tried Putty? If not, can you?
I cannot connect with other SSH client too .. I think I need to check that.
Well I see ssh running on the linux box, I am able to ping to the linux box from the windows machine. However, ssh client on the Windows box is not working. It still gives the same error ... Any suggestions what else do i need to check.
martin ◆
Are you albe to connect there with any TCP/IP client, like FTP, telnet?
I am not able to connect any TCP/IP services.
martin ◆
Seems like a firewall issue or something similar.
