WINSCP hangs the first time
Marijke Gijsel
hi,
When I start WINSCP for the first time a day , he hangs. When I start him again he runs correct.
We use WINSCP 3.7.4
Best regards,
Marijke Gijsel
marijke Gijsel
He hangs on a timeout. We start the WINSCP connection in a batch file:
winscp3.com user:password@ip-adress /script=d:\script file
Best regards,
Marijke Gijsel
OK, we are getting closer :-) But what does it do when it hangs? Connecting, uploading? Also can you post a log file?
the connection hangs. This is the log:
2005-04-28 08:54:41.812 --------------------------------------------------------------------------
. 2005-04-28 08:54:41.812 WinSCP Version 3.7.4 (Build 271) (OS 5.0.2195 Service Pack 4)
. 2005-04-28 08:54:41.812 Login time: donderdag 28 april 2005 8:54:41
. 2005-04-28 08:54:41.812 --------------------------------------------------------------------------
. 2005-04-28 08:54:41.812 Session name: sshjtinebus@194.24.88.162
. 2005-04-28 08:54:41.812 Host name: 194.24.88.162 (Port: 22)
. 2005-04-28 08:54:41.812 User name: sshjtinebus (Password: Yes, Key file: No)
. 2005-04-28 08:54:41.812 Transfer Protocol: SFTP (SCP)
. 2005-04-28 08:54:41.812 SSH protocol version: 2; Compression: No
. 2005-04-28 08:54:41.812 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-04-28 08:54:41.812 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-04-28 08:54:41.812 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-04-28 08:54:41.812 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-04-28 08:54:41.812 SFTP Bugs: -,-,-
. 2005-04-28 08:54:41.812 Proxy: none
. 2005-04-28 08:54:41.812 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-04-28 08:54:41.812 Shell: default, EOL: 0
. 2005-04-28 08:54:41.812 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-04-28 08:54:41.812 Cache directory changes: Yes, Permanent: Yes
. 2005-04-28 08:54:41.812 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-04-28 08:54:41.812 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-04-28 08:54:41.812 Looking up host "194.24.88.162"
. 2005-04-28 08:54:41.812 Connecting to 194.24.88.162 port 22
. 2005-04-28 08:54:41.906 Server version: SSH-2.0-OpenSSH_3.7.1p1
. 2005-04-28 08:54:41.906 We claim version: SSH-2.0-WinSCP_release_3.7.4
. 2005-04-28 08:54:41.906 Using SSH protocol version 2
. 2005-04-28 08:54:41.937 Doing Diffie-Hellman group exchange
. 2005-04-28 08:54:42.140 Doing Diffie-Hellman key exchange
. 2005-04-28 08:54:43.218 Host key fingerprint is:
. 2005-04-28 08:54:43.218 ssh-rsa 1024 b7:b4:f6:25:27:f3:84:28:ce:ba:0e:4d:05:ac:ed:da
. 2005-04-28 08:54:43.218 Initialised AES-256 client->server encryption
. 2005-04-28 08:54:43.218 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-04-28 08:54:43.234 Initialised AES-256 server->client encryption
. 2005-04-28 08:54:43.234 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-04-28 08:54:43.421 Using username "sshjtinebus".
! 2005-04-28 08:54:43.468 ****USAGE WARNING****
! 2005-04-28 08:54:43.468 This is a private computer system. This computer system, including all
! 2005-04-28 08:54:43.468 related equipment, networks, and network devices (specifically including
! 2005-04-28 08:54:43.468 Internet access) are provided only for authorized use. This computer system
! 2005-04-28 08:54:43.468 may be monitored for all lawful purposes, including to ensure that its use
! 2005-04-28 08:54:43.484 is authorized, for management of the system, to facilitate protection against
! 2005-04-28 08:54:43.484 unauthorized access, and to verify security procedures, survivability, and
! 2005-04-28 08:54:43.484 operational security. Monitoring includes active attacks by authorized entities
! 2005-04-28 08:54:43.484 to test or verify the security of this system. During monitoring, information
! 2005-04-28 08:54:43.484 may be examined, recorded, copied and used for authorized purposes. All
! 2005-04-28 08:54:43.484 information, including personal information, placed or sent over this system
! 2005-04-28 08:54:43.484 may be monitored.
! 2005-04-28 08:54:43.484 Use of this computer system, authorized or unauthorized, constitutes consent
! 2005-04-28 08:54:43.484 to monitoring of this system. Unauthorized use may subject you to criminal
! 2005-04-28 08:54:43.484 prosecution. Evidence of unauthorized use collected during monitoring may be
! 2005-04-28 08:54:43.484 used for administrative, criminal, or other adverse action. Use of this system
! 2005-04-28 08:54:43.484 constitutes consent to monitoring for these purposes.
. 2005-04-28 08:54:43.515 Keyboard-interactive authentication refused
. 2005-04-28 08:54:43.515 Session password prompt (sshjtinebus@194.24.88.162's password: )
. 2005-04-28 08:54:43.515 Using stored password.
. 2005-04-28 08:54:43.515 Sent password
. 2005-04-28 08:54:43.546 Access granted
. 2005-04-28 08:54:43.593 Opened channel for session
. 2005-04-28 08:54:43.656 Started a shell/command
. 2005-04-28 08:54:43.656 --------------------------------------------------------------------------
. 2005-04-28 08:54:43.656 Using SFTP protocol.
. 2005-04-28 08:54:43.656 Doing startup conversation with host.
> 2005-04-28 08:54:43.656 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2005-04-28 08:54:43.703 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2005-04-28 08:54:43.703 SFTP version 3 negotiated.
> 2005-04-28 08:54:43.703 Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< 2005-04-28 08:54:43.765 Type: SSH_FXP_STATUS, Size: 38, Number: 200
< 2005-04-28 08:54:43.765 Status/error code: 8
. 2005-04-28 08:54:43.765 Server does not recognise WinSCP.
. 2005-04-28 08:54:43.765 We believe the server has signed timestamps bug
. 2005-04-28 08:54:43.765 Getting current directory name.
. 2005-04-28 08:54:43.765 Getting real path for '.'
> 2005-04-28 08:54:43.765 Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< 2005-04-28 08:54:43.828 Type: SSH_FXP_NAME, Size: 55, Number: 528
. 2005-04-28 08:54:43.828 Real path is '/home/sshjtinebus'
. 2005-04-28 08:54:43.828 Startup conversation with host finished.
. 2005-04-28 08:54:43.843 Synchronizing local directory 'd:\dataout\camel\' with remote directory './02_fromNebus/', mode = 0, params = 2
. 2005-04-28 08:54:43.843 Listing directory "/home/sshjtinebus/./02_fromNebus".
> 2005-04-28 08:54:43.843 Type: SSH_FXP_OPENDIR, Size: 41, Number: 779
< 2005-04-28 08:54:43.906 Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> 2005-04-28 08:54:43.906 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2005-04-28 08:54:44.031 Type: SSH_FXP_NAME, Size: 6002, Number: 1036
> 2005-04-28 08:54:44.031 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< 2005-04-28 08:54:44.093 Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< 2005-04-28 08:54:44.093 Status/error code: 1
> 2005-04-28 08:54:44.093 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
. 2005-04-28 08:54:44.093 Closing connection.
. 2005-04-28 08:55:36.906 --------------------------------------------------------------------------
. 2005-04-28 08:55:36.906 WinSCP Version 3.7.4 (Build 271) (OS 5.0.2195 Service Pack 4)
. 2005-04-28 08:55:36.906 Login time: donderdag 28 april 2005 8:55:36
. 2005-04-28 08:55:36.906 Session name: sshjtinebus@194.24.88.162
. 2005-04-28 08:55:36.906 Host name: 194.24.88.162 (Port: 22)
. 2005-04-28 08:55:36.906 User name: sshjtinebus (Password: Yes, Key file: No)
. 2005-04-28 08:55:36.906 Transfer Protocol: SCP
. 2005-04-28 08:55:36.906 SSH protocol version: 2; Compression: No
. 2005-04-28 08:55:36.906 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-04-28 08:55:36.906 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-04-28 08:55:36.906 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-04-28 08:55:36.906 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-04-28 08:55:36.906 SFTP Bugs: -,-,-
. 2005-04-28 08:55:36.906 Proxy: none
. 2005-04-28 08:55:36.906 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-04-28 08:55:36.906 Shell: default, EOL: 0
. 2005-04-28 08:55:36.906 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-04-28 08:55:36.906 Cache directory changes: Yes, Permanent: Yes
. 2005-04-28 08:55:36.906 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-04-28 08:55:36.906 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-04-28 08:55:36.906 Looking up host "194.24.88.162"
. 2005-04-28 08:55:36.906 Connecting to 194.24.88.162 port 22
. 2005-04-28 08:55:36.984 Server version: SSH-2.0-OpenSSH_3.7.1p1
. 2005-04-28 08:55:36.984 We claim version: SSH-2.0-WinSCP_release_3.7.4
. 2005-04-28 08:55:36.984 Using SSH protocol version 2
. 2005-04-28 08:55:37.031 Doing Diffie-Hellman group exchange
. 2005-04-28 08:55:37.250 Doing Diffie-Hellman key exchange
. 2005-04-28 08:55:38.328 Host key fingerprint is:
. 2005-04-28 08:55:38.328 ssh-rsa 1024 b7:b4:f6:25:27:f3:84:28:ce:ba:0e:4d:05:ac:ed:da
. 2005-04-28 08:55:38.328 Initialised AES-256 client->server encryption
. 2005-04-28 08:55:38.328 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-04-28 08:55:38.328 Initialised AES-256 server->client encryption
. 2005-04-28 08:55:38.328 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-04-28 08:55:38.562 Using username "sshjtinebus".
! 2005-04-28 08:55:38.625 ****USAGE WARNING****
! 2005-04-28 08:55:38.625 This is a private computer system. This computer system, including all
! 2005-04-28 08:55:38.625 related equipment, networks, and network devices (specifically including
! 2005-04-28 08:55:38.625 Internet access) are provided only for authorized use. This computer system
! 2005-04-28 08:55:38.625 may be monitored for all lawful purposes, including to ensure that its use
! 2005-04-28 08:55:38.625 is authorized, for management of the system, to facilitate protection against
! 2005-04-28 08:55:38.625 unauthorized access, and to verify security procedures, survivability, and
! 2005-04-28 08:55:38.625 operational security. Monitoring includes active attacks by authorized entities
! 2005-04-28 08:55:38.625 to test or verify the security of this system. During monitoring, information
! 2005-04-28 08:55:38.625 may be examined, recorded, copied and used for authorized purposes. All
! 2005-04-28 08:55:38.625 information, including personal information, placed or sent over this system
! 2005-04-28 08:55:38.625 may be monitored.
! 2005-04-28 08:55:38.625 Use of this computer system, authorized or unauthorized, constitutes consent
! 2005-04-28 08:55:38.625 to monitoring of this system. Unauthorized use may subject you to criminal
! 2005-04-28 08:55:38.625 prosecution. Evidence of unauthorized use collected during monitoring may be
! 2005-04-28 08:55:38.625 used for administrative, criminal, or other adverse action. Use of this system
! 2005-04-28 08:55:38.625 constitutes consent to monitoring for these purposes.
. 2005-04-28 08:55:38.656 Keyboard-interactive authentication refused
. 2005-04-28 08:55:38.656 Session password prompt (sshjtinebus@194.24.88.162's password: )
. 2005-04-28 08:55:38.656 Using stored password.
. 2005-04-28 08:55:38.656 Sent password
. 2005-04-28 08:55:38.703 Access granted
. 2005-04-28 08:55:38.734 Opened channel for session
. 2005-04-28 08:55:38.796 Started a shell/command
. 2005-04-28 08:55:38.796 --------------------------------------------------------------------------
. 2005-04-28 08:55:38.796 Using SCP protocol.
. 2005-04-28 08:55:38.796 Doing startup conversation with host.
. 2005-04-28 08:55:38.796 Skipping host startup message (if any).
> 2005-04-28 08:55:38.796 echo "WinSCP: this is end-of-file:0"
< 2005-04-28 08:55:38.828 Microsoft Windows [Version 5.2.3790]
< 2005-04-28 08:55:38.828 (C) Copyright 1985-2003 Microsoft Corp.
< 2005-04-28 08:55:38.890 D:\DataSSH\sshjtinebus>"WinSCP: this is end-of-file:0"
. 2005-04-28 08:55:53.890 Waiting for data timed out, asking user what to do.
. 2005-04-28 08:55:53.890 Asking user:
. 2005-04-28 08:55:53.890 Host has not answered for 15 seconds.
. 2005-04-28 08:55:53.890 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
Best regards,
Marijke Gijsel
The first (working) session in the log is SFTP session. The second (not working) is SCP session. Is it mistake or is it by purpose? Read F.A.Q. (<invalid hyperlink removed by admin>) to learn how to connect with WinSCP to OpenSSH server running on Windows.
Anonymous wrote:
this is a mistake. We use sftp.
And does it hang when you really use SFTP? Can you post a log file showing that?
hi,
When the connectie hangs, I don't have a log. When I start him again, he runs correct.
2005-04-28 06:51:06.328 --------------------------------------------------------------------------
. 2005-04-28 06:51:06.328 WinSCP Version 3.7.4 (Build 271) (OS 5.0.2195 Service Pack 4)
. 2005-04-28 06:51:06.328 Login time: donderdag 28 april 2005 6:51:06
. 2005-04-28 06:51:06.328 --------------------------------------------------------------------------
. 2005-04-28 06:51:06.328 Session name: sshjtinebus@194.24.88.162
. 2005-04-28 06:51:06.328 Host name: 194.24.88.162 (Port: 22)
. 2005-04-28 06:51:06.328 User name: sshjtinebus (Password: Yes, Key file: No)
. 2005-04-28 06:51:06.328 Transfer Protocol: SFTP (SCP)
. 2005-04-28 06:51:06.328 SSH protocol version: 2; Compression: No
. 2005-04-28 06:51:06.328 Agent forwarding: No; TIS/CryptoCard: No; KI: No; GSSAPI: No
. 2005-04-28 06:51:06.328 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-04-28 06:51:06.328 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-04-28 06:51:06.328 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-04-28 06:51:06.328 SFTP Bugs: +,-,-
. 2005-04-28 06:51:06.328 Proxy: none
. 2005-04-28 06:51:06.328 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-04-28 06:51:06.328 Shell: default, EOL: 0
. 2005-04-28 06:51:06.328 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-04-28 06:51:06.328 Cache directory changes: Yes, Permanent: Yes
. 2005-04-28 06:51:06.328 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-04-28 06:51:06.328 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-04-28 06:51:06.328 Looking up host "194.24.88.162"
. 2005-04-28 06:51:06.328 Connecting to 194.24.88.162 port 22
. 2005-04-28 06:51:06.406 Server version: SSH-2.0-OpenSSH_3.7.1p1
. 2005-04-28 06:51:06.406 We claim version: SSH-2.0-WinSCP_release_3.7.4
. 2005-04-28 06:51:06.406 Using SSH protocol version 2
. 2005-04-28 06:51:06.453 Doing Diffie-Hellman group exchange
. 2005-04-28 06:51:06.703 Doing Diffie-Hellman key exchange
. 2005-04-28 06:51:07.765 Host key fingerprint is:
. 2005-04-28 06:51:07.765 ssh-rsa 1024 b7:b4:f6:25:27:f3:84:28:ce:ba:0e:4d:05:ac:ed:da
. 2005-04-28 06:51:07.781 Initialised AES-256 client->server encryption
. 2005-04-28 06:51:07.781 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-04-28 06:51:07.781 Initialised AES-256 server->client encryption
. 2005-04-28 06:51:07.781 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-04-28 06:51:08.000 Using username "sshjtinebus".
! 2005-04-28 06:51:08.046 ****USAGE WARNING****
! 2005-04-28 06:51:08.046 This is a private computer system. This computer system, including all
! 2005-04-28 06:51:08.046 related equipment, networks, and network devices (specifically including
! 2005-04-28 06:51:08.046 Internet access) are provided only for authorized use. This computer system
! 2005-04-28 06:51:08.046 may be monitored for all lawful purposes, including to ensure that its use
! 2005-04-28 06:51:08.046 is authorized, for management of the system, to facilitate protection against
! 2005-04-28 06:51:08.046 unauthorized access, and to verify security procedures, survivability, and
! 2005-04-28 06:51:08.046 operational security. Monitoring includes active attacks by authorized entities
! 2005-04-28 06:51:08.046 to test or verify the security of this system. During monitoring, information
! 2005-04-28 06:51:08.046 may be examined, recorded, copied and used for authorized purposes. All
! 2005-04-28 06:51:08.062 information, including personal information, placed or sent over this system
! 2005-04-28 06:51:08.062 may be monitored.
! 2005-04-28 06:51:08.062 Use of this computer system, authorized or unauthorized, constitutes consent
! 2005-04-28 06:51:08.062 to monitoring of this system. Unauthorized use may subject you to criminal
! 2005-04-28 06:51:08.062 prosecution. Evidence of unauthorized use collected during monitoring may be
! 2005-04-28 06:51:08.062 used for administrative, criminal, or other adverse action. Use of this system
! 2005-04-28 06:51:08.062 constitutes consent to monitoring for these purposes.
. 2005-04-28 06:51:08.062 Session password prompt (sshjtinebus@194.24.88.162's password: )
. 2005-04-28 06:51:08.062 Using stored password.
. 2005-04-28 06:51:08.062 Sent password
. 2005-04-28 06:51:08.093 Access granted
. 2005-04-28 06:51:08.140 Opened channel for session
. 2005-04-28 06:51:08.187 Started a shell/command
. 2005-04-28 06:51:08.187 --------------------------------------------------------------------------
. 2005-04-28 06:51:08.203 Using SFTP protocol.
. 2005-04-28 06:51:08.203 Doing startup conversation with host.
> 2005-04-28 06:51:08.203 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2005-04-28 06:51:08.265 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2005-04-28 06:51:08.265 SFTP version 3 negotiated.
> 2005-04-28 06:51:08.265 Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< 2005-04-28 06:51:08.312 Type: SSH_FXP_STATUS, Size: 38, Number: 200
< 2005-04-28 06:51:08.312 Status/error code: 8
. 2005-04-28 06:51:08.312 Server does not recognise WinSCP.
. 2005-04-28 06:51:08.312 We believe the server has signed timestamps bug
. 2005-04-28 06:51:08.312 Getting current directory name.
. 2005-04-28 06:51:08.312 Getting real path for '.'
> 2005-04-28 06:51:08.312 Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< 2005-04-28 06:51:08.375 Type: SSH_FXP_NAME, Size: 55, Number: 528
. 2005-04-28 06:51:08.375 Real path is '/home/sshjtinebus'
. 2005-04-28 06:51:08.375 Startup conversation with host finished.
. 2005-04-28 06:51:08.375 Synchronizing local directory 'd:\dataout\camel\' with remote directory './02_fromNebus/', mode = 0, params = 2
. 2005-04-28 06:51:08.375 Listing directory "/home/sshjtinebus/./02_fromNebus".
> 2005-04-28 06:51:08.375 Type: SSH_FXP_OPENDIR, Size: 41, Number: 779
< 2005-04-28 06:51:08.437 Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> 2005-04-28 06:51:08.437 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2005-04-28 06:51:08.578 Type: SSH_FXP_NAME, Size: 5616, Number: 1036
> 2005-04-28 06:51:08.578 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< 2005-04-28 06:51:08.625 Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< 2005-04-28 06:51:08.656 Status/error code: 1
> 2005-04-28 06:51:08.656 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
. 2005-04-28 06:51:08.656 Copying 2 files/directories to remote directory "./02_fromNebus/"
. 2005-04-28 06:51:08.656 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: No; Mask: *.*
. 2005-04-28 06:51:08.656 TM: M; ClAr: No; ExclM:
. 2005-04-28 06:51:08.656 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2005-04-28 06:51:08.656 File: "d:\dataout\camel\DLGFF_CCH_FEEDBACKRECORDS_00000015_20050427.TXT"
. 2005-04-28 06:51:08.656 Copying "d:\dataout\camel\DLGFF_CCH_FEEDBACKRECORDS_00000015_20050427.TXT" to remote directory started.
. 2005-04-28 06:51:08.656 Ascii transfer mode selected.
. 2005-04-28 06:51:08.656 Opening remote file.
> 2005-04-28 06:51:08.656 Type: SSH_FXP_OPEN, Size: 105, Number: 1795
< 2005-04-28 06:51:08.718 Type: SSH_FXP_STATUS, Size: 24, Number: 1540
. 2005-04-28 06:51:08.718 Discarding reserved response
< 2005-04-28 06:51:08.765 Type: SSH_FXP_HANDLE, Size: 13, Number: 1795
> 2005-04-28 06:51:08.781 Type: SSH_FXP_WRITE, Size: 4011, Number: 2310
. 2005-04-28 06:51:08.843 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2005-04-28 06:51:08.843 Type: SSH_FXP_CLOSE, Size: 13, Number: 2820
> 2005-04-28 06:51:08.843 Type: SSH_FXP_SETSTAT, Size: 101, Number: 2057
< 2005-04-28 06:51:09.015 Type: SSH_FXP_STATUS, Size: 24, Number: 2566
< 2005-04-28 06:51:09.171 Type: SSH_FXP_STATUS, Size: 24, Number: 2820
< 2005-04-28 06:51:09.171 Status/error code: 0
< 2005-04-28 06:51:09.171 Type: SSH_FXP_STATUS, Size: 24, Number: 2057
. 2005-04-28 06:51:09.171 File: "d:\dataout\camel\DLGFF_WCH_FEEDBACKRECORDS_00000015_20050427.TXT"
. 2005-04-28 06:51:09.171 Copying "d:\dataout\camel\DLGFF_WCH_FEEDBACKRECORDS_00000015_20050427.TXT" to remote directory started.
. 2005-04-28 06:51:09.171 Ascii transfer mode selected.
. 2005-04-28 06:51:09.171 Opening remote file.
> 2005-04-28 06:51:09.171 Type: SSH_FXP_OPEN, Size: 105, Number: 3075
< 2005-04-28 06:51:09.234 Type: SSH_FXP_HANDLE, Size: 13, Number: 3075
> 2005-04-28 06:51:09.234 Type: SSH_FXP_WRITE, Size: 97, Number: 3590
. 2005-04-28 06:51:09.281 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2005-04-28 06:51:09.281 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2005-04-28 06:51:09.281 Type: SSH_FXP_SETSTAT, Size: 101, Number: 3337
< 2005-04-28 06:51:09.343 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
< 2005-04-28 06:51:09.343 Status/error code: 0
< 2005-04-28 06:51:09.390 Type: SSH_FXP_STATUS, Size: 24, Number: 3337
< 2005-04-28 06:51:09.390 Status/error code: 0
. 2005-04-28 06:51:09.390 Closing connection.
Marijke Gijsel
So, can you get the log tomorrow, when you will be running it for the first time?
