Problem with winscp 3.7.4
robdyk
To be short. The program doesn't work !! Every time I try to upload a file, the program is "hanging".
The logfile shows nothing !!
 2005-04-24 22:37:22.937 Directory listing with --full-time succeed, next time all errors during directory listing will be displayed immediatelly.
. 2005-04-24 22:37:22.937 Startup conversation with host finished.
. 2005-04-24 22:37:37.375 Copying 1 files/directories to remote directory "/root/"
. 2005-04-24 22:37:37.375   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2005-04-24 22:37:37.375   TM: M; ClAr: No; ExclM:
. 2005-04-24 22:37:37.375   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
> 2005-04-24 22:37:37.375 echo "WinSCP: this is begin-of-file" ; scp -r  -d -t "/root" ; echo "WinSCP: this is end-of-file:$?"
< 2005-04-24 22:37:37.421 WinSCP: this is begin-of-file
. 2005-04-24 22:37:37.421 SCP remote side confirmation (0)
. 2005-04-24 22:37:37.421 File: "D:\pafiledb-modified_with_userupload\uploads\01012001.spg"
. 2005-04-24 22:37:37.421 Copying "D:\pafiledb-modified_with_userupload\uploads\01012001.spg" to remote directory started.
. 2005-04-24 22:37:37.421 Binary transfer mode selected.
> 2005-04-24 22:37:37.421 T1110910251 0 1114374581 0
. 2005-04-24 22:37:37.468 SCP remote side confirmation (0)
> 2005-04-24 22:37:37.468 C0644 195580 01012001.spg
. 2005-04-24 22:37:37.531 SCP remote side confirmation (0)
. 2005-04-24 22:37:37.531 Sending BINARY data (first block, 4096 bytes)
But it's not sending, at least not for 100%. The program (in windows Xp SP 2 just stops responding).
logfile from windows:
Type gebeurtenis:   Fout
Bron van gebeurtenis:   Application Hang
Categorie van gebeurtenis:   (101)
Gebeurtenis-ID:   1002
Datum:      24-4-2005
Tijd:      22:39:18
Gebruiker:      n.v.t.
Computer:   THUISWER-EA9168
Beschrijving:
Vastgelopen toepassing: WinSCP3.exe, versie: 3.7.4.271, vastgelopen module: hungapp, versie: 0.0.0.0, vastgelopen op: 0x00000000.
Zie Help en ondersteuning op http://go.microsoft.com/fwlink/events.asp voor meer informatie.
Gegevens:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 48 61 6e 67   ion Hang
0010: 20 20 57 69 6e 53 43 50     WinSCP
0018: 33 2e 65 78 65 20 33 2e   3.exe 3.
0020: 37 2e 34 2e 32 37 31 20   7.4.271
0028: 69 6e 20 68 75 6e 67 61   in hunga
0030: 70 70 20 30 2e 30 2e 30   pp 0.0.0
0038: 2e 30 20 61 74 20 6f 66   .0 at of
0040: 66 73 65 74 20 30 30 30   fset 000
0048: 30 30 30 30 30            00000
It's very strange to see that an old version such as 3.5.6 works ok, bt this new version (sorry to say, is a major pain in teh b*tt) !!!!
I tried several servers with Linux flavours , and they all gave the same error.
I don't know what i can do next, maybe creating a test account for you, so you can see for yourself ??
Re: Problem with winscp 3.7.4
Does SFTP protocol work? Can you try versions between 3.5.6 and 3.7.4 to find out what version the problem was introduced in?
robdyk
No sftp doesn't work either. I've tried all versions, and it turns out that the problem begins with version 3.7.2 and above.
All versions below 3.7.2 works fine (allthough version 3.7.2 is quite slow).
Maybe this will help you further ?
So does 3.7.2 work or not? :-)
I'm going to send you email with link to the development version for you to check if it has the same problem.
