WinSCP plugin for Servant Salamander
GoldenWolf
Hello!
Main feeature of WinSCP for me: parallel editing of remote files with synchronization event binded on temp file modification.
Your plugin does not support editing remote files at all :((((
Best regards,
Pavel Kudinov
GoldenWolf
1. Why i can't copy files from one WinSCP plugin panel to other? :( (i think it's so simple - to use temp file for it)
2. Why i can't execute command from a plugin like in WinSCP?
Currently:
I use WinSCP for remote working (main functions - editing of multiple remote files and grepping on server side) + Total Commander for local work (with _two_ panels - this is so coool!!!), i would prefer one good integrated program, but Servant Salamander + WinSCP plugin has no 3 very usefull functions (described below)
P.S. Sorry for my English )
Re: WinSCP plugin for Servant Salamander
This is something to be implemented in the filemanager, not in the plugin. Just like a viewer.
Re: :(((
I'll consider it.
I do not know what you mean by this.
GoldenWolf
I mean Ctrl+T, could it be realized in a Plugin? (or appling macros from WinSCP) (for me - it is the best way to find/grep/replace in files on remote server)
okay, sorry, but why you can't open an external editor from a plug-in and trace file modifications hidden from Salamander?
Re: Why i can't execute command from a plugin like in WinSCP?
Type in the command to command line below panels.
Custom command are not supported by the plugin yet. You are the first one who misses it. However it may be still think to be implemented rather by the filemanager, not by the plugin.
Sure, I can, but it would be duplicate work, because this is think the filemanager will eventually support too, I believe.
GoldenWolf
Thanks!
But i think that Filemanager implementation wouldn't work with several files simultaneously and force upload on Ctrl+S.
It would nice if you realize it, thanks again!
P.S. Sorry for my english...
