Diff between files and directories
dtoubelis
These are few suggestions:
- using diff on individual files when comparing directories vs. just size and timestamp of individual files.
- using diff to compare individual files;
- using external diff program to compare individual files;
I use WinSCP to keep a couple of remote software installations in sync and finding differences with minimum "false positives" would be extremelly helpfull.
-Dmitri
Re: Diff between files and directories
What for?
See example custom command 'File Compare' to learn how to use external diff program with WinSCP.
