Synchronization Fails
drewid
Hi I am trying to run a remote synchronization in batch mode where several gigabytes of small files are transferred. After a few minutes of running, I consistently receive an error in the client window:
Connection has been unexpectedly closed. Server sent command exit status 11.
I am using openssh server 3.6.1p2-33.30.3 and version 3.7.4 build 271 of WinSCP running on XP. Thanks in advance for your help.
-drew
Re: Synchronization Fails
What version of WinSCP are you using? Please check server's log file to find out why it closes the connection.
drewid
Message Log
For the version of WinSCP I am running, see my previous post. The log at /var/log/messages is not very informative and merely reports the connection has close. No error appears. I tried running sshd in debug mode but it didn't yield very much useful information...there was some error about a read or write failure. I could get a dump of this log if you thought it would be useful.
-drew
Re: Message Log
Sorry, I've missed it.
Please do.
BTW, do you use SFTP or SCP?
Joe Mosca
Synchronization Fails...Me too...Same error
I also get an unexpected connection fails error when I try to do a remote synchronization with many directories & jpg files.
I think it is a bug.
PS can anyone tell me how to save the synchronization sesion settings and run it automated daily?
Thank you,
Joe Mosca
joemoscaATcox.net
Re: Synchronization Fails...Me too...Same error
Can you give me more information? Is there some regularity in occurences? ...
Save your settings on login dialog and then use it from script.
