translation
slay
winscp3 source compile
I use Borland C++ Builder 6.
When i build winscp from sources after change library to Polish language i have replace resource string in Dialog Window.
In place Button Description "OK"(Tak) i have "Cancel"(Anuluj), in Dialog Title "Confirm"(Potwierdzenie) i have (&Tak)
For example:
First image is from original winscp3.exe
Second image is done after build sources winscp3.exe
In default English language everything is ok.
What i am doing wrong while build winscp3 from source that orginal translations not math ?
Re: winscp3 source compile
The reason is that compiler automatically assignes IDs to strings comming from pascal code (VCL). When you use different version of the library (for example Personal vs. Professional version, different service pack, etc.), the IDs will differ.
slay
need for another directions
Can you tell me what version of compiler etc. i should use to
that orginal version translation library WinSCP3.pl which math to winscp compiled from sources.
OR
Can you write to me short instructions how to make translation library WinSCP3.pl from PL.ini using C++ Builder 6.
Thank You, for yours answers.
Re: need for another directions
I use Personal edition with all (four?) updates.
It is quite complicated. I have PHP script to convert the PL.ini file to complete C++Builder project. You can download it, but I'm not sure it it would help you.
slay
include file
You include file inifiles.php it scants this file me.
You can place this file on forum.
Thank You[/b]
Re: Two files
slay wrote:
Sorry, but if you could place two files else
ignored.ini and all.ini
Why do you think you need them? Thay are created by the script when run with parameter "orig". But thay are useful for me only.
