direct download to folder without using temp files
eonik
too many times have i downloaded large files and either there's a problem with not enough space for temp file or the copying of finished download because the temp file takes all it's space and the file is lost.
Re: direct download to folder without using temp files
Don't use drag&drop. This was already explained many times here, please search the forum.
