Refresh and Synching of Directories
jack.stein@...
I used by accident the syn local with remote directory by clicking on the icon on the top tool bar. What I really wanted was to refresh the local view (left pane) which is in the tool bar under the top tool bar. Perhaps there should be some of the following changes:
1. Ask the user if they are sure before proceeding with the operation as it will delete many files on the remote when synching up.
2. Change the icon at the top tool bar to something different so it is not confusing with the refresh icon in the lower tool bar.
Other then that I have used the product on Windows XP and it is great.
Jack Stein
Re: Refresh and Synching of Directories
Sorry, but if the synchronise options dialog have not stopped you, do you think that simple message box would?
Anyway since the next version the synchronisation will not delete files by default. Of course, this would affect fresh installation only.
