Great Utility...Couple questions
Guest12345
I'm using scripts to sync directories on a daily basis. I was wondering how you pass the syncdelete parameter? I see it as an option but there is no example.
Also, are there any levels of logging? I'd like a lot less detail to sort thru.
Thanks again for the great app.
Jason
Re: Great Utility...Couple questions
option synchdelete <value>
See "help option"
No. The logging as is is primarily intended for debugging, so useful only for me :-) I plan to add logging useful for users too (like logging transfered files...).
