background queue
sasquatch
background queue
When I am copying or moving files using the background queue, sometimes the connection to file gets lost and the entire queue will stop because of the error msg. I will then requeue the file to move or copy again if it wasn't complete the first time. Is it possible to set an option, to retry the file if the connection is lost or maybe add it back to the bottom of the queue and let the queue keep processing? The error I ususally get is "connection reset by peer". Maybe it might be possible to skip the queue item with the error and move onto the next item?
Thanks a lot
Re: background queue
This is quite difficult to implement.
This is easier (still not easy :-)). I'll consider it.
Could you just make it so that when the reconnect dialog appears, the background transfers still continue or reconnect? I'm trying to move a gig of data and my server is sometimes unreliable on SSH because of the firewall run by another company. To keep having to hit reconnect, highlight, then transfer, then confirm and wait, then do it again an hour later is mildly irratating. Is there a better way??!
Dug
If it were that easy... :-)
