How to use custom command?
Gill
Hi, everyone:
I have a problem.
What's custom command and how to use ?
I wanna put some files to remote server,
If SFTP files ok, move these files to another folder in Windows client.
But it can't work about custom command.
For example use !mv or !cp.
how can I do?
It can't recognize about an exclamation mark.
I'm very confused about this.
Please tell me if you have any answer.
Thanks a lot of.
Gill
Gill
Re: How to use customer command ?
Very sorry!!
I describe my question not clear!
I use winscp3.com in Windows BAT file.
It can't work if I use ! command.
How can I use ! command in winscp3.com or command line model?
Is it feasible?
OK, so you want to execute server-side command from the script, do you? You cannot do this with WinSCP, yet.
