Confirmation message when using exclude mask
I am using WinSCP 3.72 (build 262)to upload files to a server using SSH (norton Commander interface)
My main problem is, if I want to exclude certain files (for example, the CVS folders that are created by the CVS system), using the "Exclude mask" function which appears in the upload dialog, I am getting a confimation dialog each time it finds something which matches the exclussion mask, so I have to press "Continue" each time.
For cases in where I just have a pair of files which match is ok, but when I have lots of, it's so tiring to upload the whole content having to click "Continue" on each folder (because CVS tends to create a CVS folder in each folder, as you know). An upload which could take 2 minutes can be up to 10 minutes or something like that.
I don't know if that does occur only for me, or if it is a feature. I haven't found any other post about that.
By the way thank you for your great work. This program is simply wonderful, rules SO MUCH!
Re: Confirmation message when using exclude mask
Please post full text of the confirmation message as I have no idea what message you mean.
The message is:
Copying file 'C:\TEMP\testme\cvs' failed
And then we have two buttons: Ok, Abort
Thanks, I see. I'll fix it.
Am I right that it happens only for files/directories in subdirectories?
Anyway to avoid it, switch to SFTP protocol.
Thank you, prikryl!
Yes, it occurs only when uploading whole dirs and it finds files which match the mask.
I am afraid I cannot use SFTP. I think I can stand with this... but I would be very cool not to have this confirmation message, of course. I'll stay tuned ;)
Thank you so much again!
sole
Quite nice to see you fixed that in the latest version!!
Thank you so much... this is a very good software! I'm really impressed. :D
