Organizing stored sessions
ShaiHu
I have many stored sessions.
I think it would be nice and convenient if I could organize them in folders or any such idea.
Thanks,
Shai
DaveOfTheDogs
Re: Organizing stored sessions
I want to be the one to second this request. I have about 50 sessions stored from 5 or 6 different environments. Currently, I preface the server name with the environment name, like "qa: ecomapp01." It would be nice to have folders.
-David
It'd be good to store the sessions as suggested in a folder (default in the winscp directory?). Alternatively in an .ini file, so they can be easily copied to another PC. Copying them from registry is a pain!
Regards John
the topic is about something different. It was asked to allow organizing sessions in folder, but visually (on login dialog), not physically on disk. You can already store them to an INI file.
pong
I am the third.
It is very useful to have any possibility to organize sessions into the subfolders, groups etc. in the case of many saved sessions.
_________________
pong
Reply with quote E-mail
Stored Session Organization
This would be a great benifit if we can get folder organization and if we can then create shell icons for those folders. We would then be able to drag and drop to folder icon and distribute files to those saved sessions.
Re: Stored Session Organization
Maybe :-)
Both is poossible, see Shell icon button on Stored sessions tab of login dialog.
I understand and appreciate this feature. But would it be possible to create this "shell folder" with multiple stored sessions inside so that if I drop a file on the "folder" it would open multiple sessions and distribute files to all endpoints simultaneously, instead of having to drag and drop for each of the shell icons. Thanks
Sorry, I've missed the plural :-) It should not be difficult to achive that using scripting.
cweaver
Yes to folders!
Take a look at SecureCRT for a good example on managing sessions.
You can create folders, drag entries between folders, copy an existing session (very nice for many sessions that only have slight differences such as IP address or user).
chrfyv
I would like to see a folder organization of sessions too please. Just a simple folder org would help me considerably.
Its a great product, and I use it with about 20 - 30 machines.
I might have to login with 2 different logins - depending on the purpose.
spudthedestroyer
+1
I manage a heck of a lot of machines and without a tree / folder or some kind of logical grouping its become a bit of a nightmare.
Would love to see some structuring options regarding storing the sessions.
aXon
Session organizing is very usefull feature. I would love it, cause im getting old while scrolling endless list of servers :wink:
