[PATCH] Force use UTF-8 for remote site in SFTP
twu2
Is possible to add this option? Because the sftp-server not support version 4 protocol, but the locale for SFTP server site use UTF-8.
Attached is the patch.
In this patch, I also remove the check for filename with \\, because for Big5 Chinese (or CP950), some Chinese word use this.
diff -Nur winscp.orig\core\SessionData.cpp winscp.patch\core\SessionData.cpp
--- winscp.orig\core\SessionData.cpp   Tue Feb 08 17:02:06 2005
+++ winscp.patch\core\SessionData.cpp   Tue Mar 01 16:12:34 2005
@@ -498,6 +498,7 @@
     READ_SFTP_BUG(Symlink);
     READ_SFTP_BUG(Utf);
     READ_SFTP_BUG(SignedTS);
+    READ_SFTP_BUG(ForceUtf);
     #undef READ_SFTP_BUG
     SFTPMaxVersion = Storage->ReadInteger("SFTPMaxVersion", SFTPMaxVersion);
@@ -673,6 +674,7 @@
       WRITE_SFTP_BUG(Symlink);
       WRITE_SFTP_BUG(Utf);
       WRITE_SFTP_BUG(SignedTS);
+      WRITE_SFTP_BUG(ForceUtf);
       #undef WRITE_SFTP_BUG
       WRITE_DATA(Integer, SFTPMaxVersion);
diff -Nur winscp.orig\core\SessionData.h winscp.patch\core\SessionData.h
--- winscp.orig\core\SessionData.h   Tue Feb 08 17:01:30 2005
+++ winscp.patch\core\SessionData.h   Tue Mar 01 16:11:48 2005
@@ -22,7 +22,7 @@
 enum TSshBug { sbIgnore1, sbPlainPW1, sbRSA1, sbHMAC2, sbDeriveKey2, sbRSAPad2,
   sbRekey2, sbPKSessID2 };
 #define BUG_COUNT (sbPKSessID2+1)
-enum TSftpBug { sbSymlink, sbUtf, sbSignedTS };
+enum TSftpBug { sbSymlink, sbUtf, sbSignedTS, sbForceUtf };
 #define SFTP_BUG_COUNT (sbSignedTS+1)
 enum TAutoSwitch { asOn, asOff, asAuto };
 enum TPingType { ptOff, ptNullPacket, ptDummyCommand };
diff -Nur winscp.orig\core\SftpFileSystem.cpp winscp.patch\core\SftpFileSystem.cpp
--- winscp.orig\core\SftpFileSystem.cpp   Wed Feb 09 09:41:30 2005
+++ winscp.patch\core\SftpFileSystem.cpp   Tue Mar 01 16:29:14 2005
@@ -292,7 +292,8 @@
   inline void AddPathString(const AnsiString Value, int Version, bool Utf)
-    AddString(Value, (Version >= 4) && Utf);
+//    AddString(Value, (Version >= 4) && Utf);
+    AddString(Value, Utf);
   void AddProperties(unsigned short * Rights, AnsiString * Owner,
@@ -458,7 +459,8 @@
   inline AnsiString GetPathString(int Version, bool Utf)
-    return GetString((Version >= 4) && Utf);
+//    return GetString((Version >= 4) && Utf);
+    return GetString(Utf);
   void GetFile(TRemoteFile * File, int Version, bool ConsiderDST, bool Utf, bool SignedTS)
@@ -1277,6 +1279,7 @@
   FAvoidBusy = false;
   FUtfStrings = false;
   FSignedTS = false;
+  FForceUtf = false;
   FSupport = new TSFTPSupport();
   FSupport->Extensions = new TStringList();
   FExtensions = new TStringList();
@@ -2242,23 +2245,32 @@
+  FForceUtf = (FTerminal->SessionData->SFTPBug[sbForceUtf] == asOn);
   if (FVersion >= 4)
-    FUtfStrings = (FTerminal->SessionData->SFTPBug[sbUtf] == asOff) ||
-      ((FTerminal->SessionData->SFTPBug[sbUtf] == asAuto) &&
-        (FTerminal->SshImplementation.Pos("Foxit-WAC-Server") != 1));
-    if (FUtfStrings)
+    if (FForceUtf)
-      FTerminal->LogEvent("We will use UTF-8 strings when appropriate");
+      FUtfStrings = true;
     else
-      FTerminal->LogEvent("We believe the server has SFTP UTF-8 bug");
+      FUtfStrings = (FTerminal->SessionData->SFTPBug[sbUtf] == asOff) ||
+      ((FTerminal->SessionData->SFTPBug[sbUtf] == asAuto) &&
+        (FTerminal->SshImplementation.Pos("Foxit-WAC-Server") != 1));
   else
-    FUtfStrings = false;
+    FUtfStrings = FForceUtf;
+  if (FUtfStrings)
+    FTerminal->LogEvent("We will use UTF-8 strings when appropriate");
+  else
+    FTerminal->LogEvent("We believe the server has SFTP UTF-8 bug");
@@ -2442,7 +2454,8 @@
           File = LoadFile(&ListingPacket, NULL, "");
           // security fix
           if (((File->FileName.Length() > 2) && IsDots(File->FileName)) ||
-              (File->FileName.Pos("/") > 0) || (File->FileName.Pos("\\") > 0))
+              (File->FileName.Pos("/") > 0))
+//              (File->FileName.Pos("/") > 0) || (File->FileName.Pos("\\") > 0))
             FTerminal->LogEvent(FORMAT("Ignored suspicious file '%s'", (File->FileName)));
             delete File;
diff -Nur winscp.orig\core\SftpFileSystem.h winscp.patch\core\SftpFileSystem.h
--- winscp.orig\core\SftpFileSystem.h   Wed Feb 09 09:40:30 2005
+++ winscp.patch\core\SftpFileSystem.h   Tue Mar 01 16:13:25 2005
@@ -76,6 +76,7 @@
   TSFTPSupport * FSupport;
   bool FUtfStrings;
   bool FSignedTS;
+  bool FForceUtf;
   void __fastcall CustomReadFile(const AnsiString FileName,
     TRemoteFile *& File, char Type, TRemoteFile * ALinkedByFile = NULL,
diff -Nur winscp.orig\forms\Login.cpp winscp.patch\forms\Login.cpp
--- winscp.orig\forms\Login.cpp   Wed Feb 09 21:35:02 2005
+++ winscp.patch\forms\Login.cpp   Tue Mar 01 16:21:30 2005
@@ -94,6 +94,7 @@
   InitializeBugsCombo(SFTPBugSymlinkCombo);
   InitializeBugsCombo(SFTPBugUtfCombo);
+  InitializeBugsCombo(SFTPBugForceUtfCombo);
 void __fastcall TLoginDialog::Init()
@@ -231,6 +232,7 @@
       if (SFTPBug ## BUG ## Combo->ItemIndex < 0) SFTPBug ## BUG ## Combo->ItemIndex = 0
     LOAD_SFTP_BUG_COMBO(Symlink);
     LOAD_SFTP_BUG_COMBO(Utf);
+    LOAD_SFTP_BUG_COMBO(ForceUtf);
     #undef LOAD_SFTP_BUG_COMBO
     // Authentication tab
@@ -495,6 +497,7 @@
   #define SAVE_SFTP_BUG_COMBO(BUG) aSessionData->SFTPBug[sb ## BUG] = (TAutoSwitch)(2 - SFTPBug ## BUG ## Combo->ItemIndex);
   SAVE_SFTP_BUG_COMBO(Symlink);
   SAVE_SFTP_BUG_COMBO(Utf);
+  SAVE_SFTP_BUG_COMBO(ForceUtf);
   #undef SAVE_SFTP_BUG_COMBO
   // Proxy tab
diff -Nur winscp.orig\forms\Login.dfm winscp.patch\forms\Login.dfm
--- winscp.orig\forms\Login.dfm   Wed Feb 09 23:40:12 2005
+++ winscp.patch\forms\Login.dfm   Tue Mar 01 16:33:28 2005
@@ -969,7 +969,7 @@
           Left = 0
           Top = 6
           Width = 345
-          Height = 70
+          Height = 100
           Anchors = [akLeft, akTop, akRight]
           Caption = 'Detection of known bugs in SFTP servers'
           TabOrder = 0
@@ -992,6 +992,14 @@
             Caption = 'Does not use &UTF-8 for SFTP4 and newer'
             FocusControl = SFTPBugUtfCombo
           end
+          object Label34: TLabel
+            Left = 12
+            Top = 68
+            Width = 115
+            Height = 13
+            Caption = 'Force remote use UTF-8'
+            FocusControl = SFTPBugForceUtfCombo
+          end
           object SFTPBugSymlinkCombo: TComboBox
             Left = 272
             Top = 15
@@ -1011,6 +1019,16 @@
             ItemHeight = 0
             TabOrder = 1
+          end
+          object SFTPBugForceUtfCombo: TComboBox
+            Left = 272
+            Top = 63
+            Width = 61
+            Height = 21
+            Style = csDropDownList
+            Anchors = [akLeft, akTop, akRight]
+            ItemHeight = 0
+            TabOrder = 2
           end
         end
       end
diff -Nur winscp.orig\forms\Login.h winscp.patch\forms\Login.h
--- winscp.orig\forms\Login.h   Thu Jan 27 21:27:00 2005
+++ winscp.patch\forms\Login.h   Tue Mar 01 16:20:50 2005
@@ -232,6 +232,8 @@
   TRadioButton *IPv6Button;
   TLabel *Label33;
   TComboBox *BugRekey2Combo;
+  TLabel *Label34;
+  TComboBox *SFTPBugForceUtfCombo;
   void __fastcall DataChange(TObject *Sender);
   void __fastcall FormShow(TObject *Sender);
   void __fastcall SessionListViewSelectItem(TObject *Sender,
Re: [PATCH] Force use UTF-8 for remote site in SFTP
Thanks for the patch!
It seems useful, so unless I find some problem with it, I'll add this to the next release.
Is there any way to autodetect the server for which the patch is necessary?
Can I somehow detect if the \\ in the filename is really path delimiter or special character in Big5 encoding?
twu2
For autodetect? I don't know, so I make this an option for user to enable or disable it by himself for each session.
For big5 encoding, I think there is no way to check if we check the string byte by byte. (Big5 is 2 bytes character)
I've another ideal to check this one, just convert it to UTF-8 again if we find \\, then check it again. Because after the convert, if \\ included in a regular big5 word, it will convert to another ascii byte, if it is really path delimiter, it should still as \\.
Like this one:
+++ winscp.patch\core\SftpFileSystem.cpp   Wed Mar 02 16:17:22 2005
@@ -2442,16 +2454,35 @@
           // security fix
             delete File;
           else
-            FileList->AddFile(File);
+            // if we find \\, try convert to UTF-8 then check again
+            if (File->FileName.Pos("\\") > 0)
+              AnsiString tmpstr = EncodeUTF(File->FileName);
+              if (tmpstr.Pos("\\") > 0)
+                FTerminal->LogEvent(FORMAT("Ignored suspicious file '%s'", (File->FileName)));
+                delete File;
+              else
+                FileList->AddFile(File);
+                Total++;
+            else
-            Total++;
+              Total++;
           if (Total % 10 == 0)
What kind of server it is? (OpenSSH?)
I'm not sure if I understand this. Do you mean that first conversion from UTF-8 converts the filename to another multibyte character set (Big5)? And what does the second conversion?
twu2
Yes
no, in ReadDirectory(), the filename we received from sftp-server is already Big5 (even if remote sending UTF-8 to us, we'll convert it from UTF-8 to ansi first, Windows use Big5 for Chinese encoding default).
If we find \ in the filename, it maybe a regular path delimiter or a byte in Chinese big5 word.
If we want to know it is belong to a Chinese big5 word or not, we just convert the string from Big5 to UTF-8, if that's a byte in Chinese big5 word, it will change to another ascii code, so we check the UTF-8 string again to make sure it's path delimiter or not.
Like this:
for (unsigned long Index = 0; Index < Count; Index++)
  // security fix
    delete File;
  else
    // check \ in filename or not
    if (File->FileName.Pos("\\") > 0) {
      // find \, but we want to make sure it's not a byte of a MBCS word, like Chinese Big5
      // so we convert the filename to UTF-8
      // then check again
      FTerminal->LogEvent(FORMAT("Finding \\ for '%s'", (File->FileName)));
      FTerminal->LogEvent(FORMAT("Convert to for '%s'", (tmpstr)));
      if (tmpstr.Pos("\\") > 0) {
        // still find \ in UTF-8 filename, so it is a path delimiter, ignore this one
        delete File;
      else {
        Total++;
    else {
      Total++;
yes
On what OS? Is it standard build or some patched version?
if we want to know it is belong to a Chinese big5 word or not, we just convert the string from Big5 to UTF-8, if that's a byte in Chinese big5 word, it will change to another ascii code, so we check the UTF-8 string again to make sure it's path delimiter or not.
Can you try if it helps to use IsPathDelimiter() function? From VCL help:
Call IsPathDelimiter to determine whether a position in the string S contains the path delimiter character ("\"). Positions are numbered from 1.
When working with a multi-byte character system (MBCS), IsPathDelimiter distinguishes between a true delimiter character, and the byte of the same value that can appear as the second byte of a double byte character.
To test for more characters than just the delimiter, use IsDelimiter.
twu2
Debian Sarge standard build.
No, IsPathDelimiter() not always work.
For example, if we call IsPathDelimiter() for each index of string:
"\xB3\x5C\xA5\x5C\xA5\x5C" => always false.
"\xB3\x5C\xA5\x5C\x5C\xA5\x5C" => true for index = 5.
"\xB3\x5C\xA5\x5C\xA5\x5C\x5C" => always false.
For the third string, it should return true, but use IsPathDelimiter() will return false.
I think convert to UTF-8 then check it again is more easy.
twu2
Sorry, that's my fault... the index should start from 1.
I test it again.
IsPathDelimiter() works.
int i, len;
len = File->FileName.Length();
bool found = false;
for (i = 1; i <= len; i++) {
  if (IsPathDelimiter(File->FileName,i)) {
    found = true;
    break;
if (found) {
