tilde in old file..
more on save renamed
I see this feature and is good when you overwrite or delete...but what happens when you are editing and you save. If you make a mistake and save, your old file is history.
Also...If you are working on a machine with multiple folders you need to go into the pre-selected directory and find the file.
I think it would be nice if edited files were renamed(not necessarily with tilde) and saved in same directory.
Re: more on save renamed
OK, I haven't realised that the "recycle bin" does not work when editing. I consider your request. So maybe in the next version :-)
