console and script support
Gill
Re: console and script support
You can run winscp3.com /script=ftp.scr in command line mode.
First you must creat ftp script named ftp.scr
Example:
option batch on
option transfer binary
open sftp://userid:password@host
get * DownloadFiles\
close
gibic wrote:
how can i run winscp in command line mode? And can i run ftp script? how?
brianp
Running from a ColdFusion Page
I've written a script file that functions flawlessly when I run it from the command line, however when I attempt to launch it from a ColdFusion template, I get an error in the log file saying: "The server's host key is not cached in the registry."
I understand that the key is stored by user, so I assume there's two ways I can solve this. 1) copy the key (don't know where from / to) in the registry or 2) modify the script, a least once, to respond to the prompt "add this host key to the registry" (also, not something I know how to do in the script file) - then I assume I would be fine.
Any advice would be greatly appreciated.
Re: Running from a ColdFusion Page
Please read F.A.Q.
