Why cannot watch for changes in more directories?
Vacilando
Slovakia
Hi - congrats; this is amazing software!
One question (I did not find it in FAQ nor this forum) - I tried to use the function "keep directory up to date" for my mail repository (Thunderbird) but I got a message "Cannot watch for changes in more then 500 directories and subdirectories".
Why this limitation? I can imagine it would get a bit slow, but I can bear that.
I would really love to be able to keep a current copy of my mail repository on the server, so that I can access it from anywhere.
Thanks a lot,
Vacilando
_________________
Travel in All Senses
https://www.vacilando.org/
Mdknapp
Is the 500 directory limitation removed?
First thanks for the great program!
I noticed that you said you could removed the 500 directory limitation, is this done? We are desperately needing it lifted as we have a ton of language directories...
Is it an option to remove the limit someplace? I tried searching but have not seen anything to answer this question.
THanks,
Matthew
Re: Is the 500 directory limitation removed?
No it is not done yet, neither there is option for this.
Thanks for the quick reply. Any idea of timeframe for a build released with the constant changed? Just trying to get an idea.
Thank you for your time.
Matt
It will take several weeks at least. However if you send me an email I can send it to you earlier.
