console version doesn't take the PWD / passphrase for a key
GK
Could you kindly help me out. I am using console version to upload file to SFTP site www.firepay.com. It doesn't take the password but prompts me to enter passphrase for a key.
Here are the commands in the batch file
option batch on
open username@mercbatch.firepay.com
password
cd incoming
put e:\optimal\transa~1\pendin~1\trialone.txt
close
And I use this command:
winscp3.com /script=abc.txt
Re: console version doesn't take the PWD / passphrase for a key
You cannot specify the password this way. Either save the password to the stored session or save the key without passphrase.
