Problem with synchronize and partially transmitted files
Paulo
Hi:
To start, excellent program!
I'm trying to sync my Linux home server with my Windows XP work machine. I create this script:
C:\PROGRA~1\WinSCP3>more homebackup.txt
option batch on
open rsync@xxx.xxx.org
cd /data
synchronize local c:\homebackup /data
close
It's been running successfully, until one session failed with an partially transferred file. Now I get this error:
Local 'c:\homebackup\profiles\lea\Desktop\CSA\2-8-2005_files' <= Remote '/data/profiles/lea/Desktop/CSA/2-8-2005_files'
zlsSetup_55_062_011.exe | 0 kB | 0.0 kB/s | binary | 0%
Target directory contains partially transfered file 'zlsSetup_55_062_011.exe'.
o you want to resume file transfer? Note: Answering 'No' would delete partially
transfered file and restart transfer.
(Y)es, (N)o, (A)bort: Abort
Session 'rsync@chilux.ods.org' closed.
No session.
I understand what is going on, but this is an unnatended process, so I can't be there to answer. I checked the documentation (gasp!!) and it seems the "option batch on" should answer a "no" to that question. So is this a bugor I didn't understand the documentation?
Version is 3.7.4 (build 271).
thanks
Paulo
Re: Problem with synchronize and partially transmitted files
This is known drawback. I'll solve it somehow in the next version. As temporary workaround you may disable resuming at all or disable resume confirmation in the GUI. Whatever you prefer. It will affect the scripting too.
LP
Was this problem ever resolved? We occasionally run into the same problem.
Paulo wrote:
Hi:
option batch on
cd /data
close
No session.
thanks
Paulo
