Reporting Bugs -> My first
Laibsch
thank you for winscp it is awesome!
I was wondering why apparently there is no way to report bugs against winscp. Well, I have a minor bug to report. When one uses Winscp with the German language pack and right-clicks a soft-link on the remote side to get to "Eigenschaften" aka Properties, it says "Verknüpfung vor" aka "Link to" where it should say "Verknüpfung mit".
Keep up the good work.
Best regards
Laibsch
Re: Reporting Bugs -> My first
That's what this forum is good for.
I'll propagate your objection to german translator.
Marko Meister
fixed
I have fixed the problem. The old string was not only bad translated but also too long. it was
Verknüpfung
Now it reads
verknüpft mit:
I think that is better. Thank you for the report.
mm
