assertion in 3.7.2-3.7.4 connecting thru SOCKS 5
Marc
This works fine in 3.7.1 but fails in later versions:
Here is the config, which I suspect is causing it (because other more "normal" [non-proxied] connections work fine):
localhost:1080 is PuTTY port forwardind to a remote SOCKS proxy.
Let me know if you need any other info to debug this. I'd be glad to help. Email me at msabramo@yahoo.com
Jerry2005
Same problem
Hi everybody,
I have the same problem with 127.0.0.1 and socks4.
By the way: I searched a lot but have not been able to find a bugtracker or bug-forum for this message, 'til I finally found this topic.
Probably considering some time to do a "buf-forum"?
Thanks in advance,
sincerely
Tom Wiegand
Re: Same problem
I have made attempt to fix this. Unfortunately I do not have any SOCK proxy to debug it myself.
Re: Same problem
That's what the support forum is for.
1) I do not think it is up to the end user to decide if
something is bug or not. You post it here. I decide if it is bug or your misunderstanding :-) If course in this case, it is quite obvious, but it is seldom so.
2) Most people does not care where do they post their messages. So if they do not differentiate between "support" forum and "feature requests" forum, adding third forum wouldn't change anything.
Re: Same problem
OK, I already know that I have not fixed it. I also know by sure that the problem is in PuTTY code, so I'll ask them for help.
I believe that workaround would be to check Consider proxying local host connections on Proxy tab.
mava70
Same problem
No probme with 3.4.2 trought my socks5 proxy, 3.7.4 doesn't work. Looking for 3.7.1 to see it it works
M
Re: Same problem
mava70 wrote:
I can confirm tha 3.7.1 works for me
I would rather like to know if 3.7.4 works for you when Consider proxying local host connections is checked. Thanks in advance.
Marc
Re: Same problem
I am able to connect with that setting checked in 3.7.4
Thanks,
-Marc
Re: Same problem
Thanks for letting me know.
bernhard
Re: Same problem
i had the same problems as mentioned above. checking "Consider proxying local host connections" works!
Thanks!
