With new Version 3.7.3 can not more copy as 124kb filessize
slaukas
I have update the old Version 3.7.2 with the new 3.7.3.
Since this update. i can not send Files bigger than 124 KB. After this
the Timeout screen (...15 sec) is visible and the session was ended.
I go back to the old version , and the filetransfer run witout any problems
It's a bug or a new feature ??? :D :D :D
i haven't encountered any problem regarding file copy locally and remotely with a filesize larger than 124 KB... I tried it myself...
Re: With new Version 3.7.3 can not more copy as 124kb filessize
What protocol, SCP of SFTP? Can it be the same problem as in this topic?
slaukas
3.7.3 SCP Problem
I have tested your new Fix2 (for the scp transfer Problem with the version 3.7.3) and it's looks ok !!
Without the Fix-release, the error is only with scp not with sftp.
Re: 3.7.3 SCP Problem
Thanks.
