source ALMOST compiles for me ;)
dustball
Baltimore, MD, USA
I have Borland C++ Builder 6, and I'm having a little trouble. Specifically the libraries Moje_B5.lib/bpi and DriveDir_B5.lib/bpi won't build.
What is the correct procedure for making these LIBs? Project, New Library, add the files, and build right? I get all kinds of syntax errors, or a TLIB error (invalid 'k' in command line).
-or- could you possibly just post the compiled versions of Moje & DriveDir?
Thanks!
Brian
Re: source ALMOST compiles for me ;)
I've forgot to include project file ot packages to archive. I'll fix this with next relaese.
Thanks!
