Command Line Synchrnozation
edernest
I am trying to setup remote directory synchronization using a command line script and Windows Scheduled Tasks. It seems to work as I have it setup, but I'm not sure how to get the remote directory to delete files that have been deleted on the local machine. In the GUI, I see that option is a checkbox that is checked by default. In the help for the "synchronize" command I see:
efffective options:
transfer, synchdelete
but, I do not see how to use them or a description of what those options do. I think synchdelete is what I am looking for. Any ideas on how to use those options?
Re: Command Line Synchrnozation
efffective options:
Use command "option synchdelete on", see "help option" for details.
Thanks, just what I was looking for. I see that this option gets reset to off after you terminate the app, so I've added this to my script.
