Filename Copy to Clipboard
Wolfgang
:( I use Ver. 3.7.2 with WinXP Prof. SP2 .
The two Functions "Copy filename to clipboard (with path)" do not work properly. I get 2 lines:
scp://host/filename
scp://host/path/filename
or with copy with path 2 times the second line.
Copying the URL is correct (only 1 times the second line).
Re: Filename Copy to Clipboard
Thanks for letting me know. It is stupid bug. You may downgrade to 3.7.1, where it works. Sorry for inconvenience.
